11-20-2010, 10:07 AM   #1
Sigma EF-530 DG Super questions
I just received Sigma EF-530 DG Super for my K20d. I have couple of questions. When in low-light setting using PTTL mode, the iso is set at least 1600 by camera. Is that a bad thing in term of noise level? The pictures came up fine btw. I just concerned about the high iso. If I set the camera to SV mode to control the iso below 800, will the Flash adjust the setting according in TTL mode? Which brand of diffuser or bouncer with with this flash? Any good references on using the flash as the user guide is not easy to understand?
11-20-2010, 10:42 AM   #2
If the flash is set to P-TTL, the camera will set the lighting output to whatever is needed. When working with flash, it is often better to work with the camera mode dial set to "X" or "M", and set the ISO to whatever you want. The lower the ISO, the better in term of noise. If you set the camera to "X", then you just set the aperture you want to control the depth of field, and the camera will handle everything else. When you set the camera to "M" (manual), you can control how the background appears in term of brightness. It can also be used to record movement in the background, while the subject looks (almost) sharp and properly exposed.
11-20-2010, 11:41 AM   #3
Manel Brand's Avatar
A diffuser compatible with the Pentax AF500FTZ/Canon380Ex/Nikon SB26 fits in the Sigma EF-530; as for guides or tutorials, this definitely worth a reading:
Digital SLR and P-TTL flash guide
Also you can watch the AF560FGZ Hot Shoe Flash Tutorial from Pentax Imaging; it's a tutorial on the Pentax flash wireless capabilities but it may help to understand how to set up the Sigma as well. Look for the watch demo link below the flash description.
AF540FGZ - Official PENTAX Imaging Web Site
11-20-2010, 07:01 PM   #4
Another question
When I turn the flash face up or down, I can hear something is loose inside. is that normal?
11-21-2010, 02:34 AM   #5
QuoteOriginally posted by hoyquest Quote
Yes. I can hear some noise with mine; I think it's the built-in wide panel that has some slack space to move around.
11-21-2010, 04:01 AM   #6
hoanpham's Avatar
Nop. I have 2, not a single noise.
camera, dg, dslr, ef-530, flash, iso, mode, photography, questions, sigma, sigma ef-530 dg
Some Sigma EF-530 Super questions Eruditass Flashes, Lighting, and Studio 4 11-11-2010 12:35 AM
Can Sigma 530 DG GT trigger Sigma 530 DG Super ? eva2000 Flashes, Lighting, and Studio 5 12-07-2008 03:14 PM
Some questions about Sigma EF-530 Super flash Idanz0r Flashes, Lighting, and Studio 14 11-30-2008 01:42 PM
sigma EF-530 D flash users: quick questions mattdm Flashes, Lighting, and Studio 3 11-18-2008 09:57 AM
Sigma EF-530 DG SUPER or EF-500 DG SUPER figmental1978 Flashes, Lighting, and Studio 7 10-01-2007 06:06 AM
All times are GMT -7. The time now is 03:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
