09-23-2007, 05:40 PM   #1
K100D battery level indicator blinks
The battery level indicator on my k100D blinks when I try to turn the camera on and the camera won't turn on. The manual says this happens when "the camera turns off after displaying a message". I don't rememebr any message the last time I used it. I have tried new batteries, both re-chargeable and regular. Nothing helps. Any ideas? Yes, I'm sure the batteries are inserted correctly. I've also cleaned the battery contacts in the camera. I have not updated the firmware.
Is there a way to reset the camera?
Thanks for your help.
09-23-2007, 11:21 PM   #2
Arjay Bee's Avatar
Check that the sd card door and the battery door is closed properly and if so that the little switch under the door is depressed.
09-23-2007, 11:59 PM   #3
Hmmm this happened to me when my batteries failed in the middle of a bulb shot... the indicator stayed on even while the camera was off... it went back to normal after I changed fresh batteries though...
09-24-2007, 05:59 AM   #4
I took the batteries out and left them out for about 4 hours then popped them back in. The camer then worked normally. Must have done a "reset" somehow. Thanks for the help.
09-24-2007, 06:00 PM   #5
Welcome to Pentax Forums Dan.
That's how you reset our cameras.
Usually 10 min will do it
Have fun with it, and I hope that you post some more.
batteries, battery, battery level indicator, camera, dslr, indicator, k100d, level, photography
Is the battery Indicator problem resolved in K-x after ver1.01 ? srini Pentax DSLR Discussion 10 05-03-2010 10:29 AM
K-7 Level indicator Question VHDEL Pentax DSLR Discussion 5 07-16-2009 08:16 AM
For Sale - Sold: Battery Grip for K100D/K110D/K100D Super Camera, K10D/K20D D-LI50 Battery frank Sold Items 12 05-30-2009 06:10 PM
What Makes The k100d "Entry Level" shutterpuppy Pentax DSLR Discussion 6 03-30-2008 03:15 AM
Battery indicator for DS RussellW Pentax DSLR Discussion 5 02-19-2007 10:39 AM
All times are GMT -7. The time now is 04:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
