11-24-2010, 03:42 PM   #1
cosmicap's Avatar
Can flash unit damage DSLR?
Up until now I have only used the built-in flash in my K200D. Thinking about buying an external. Apparently flashes can have either or both of High Voltage or Low Voltage triggers - whatever that means. Sounds like it might be important as apparently installing a HV flash on some new digital cameras can actually damage the camera. Does anyone have some knowledge about this? How can one tell whether HV or LV trigger and is there any truth in the damage risk? Obviously any Pentax flash would be fine but how about OEMs?
Thanks,
Pete
11-24-2010, 05:08 PM   #2
Flash made within the past 5-10 years should be fine.Up to 20 volts trigger,should not harm todays new DSLR.Use a volt meter to check ground and main hot shoe contacts,with flash turned on.I use an old Minolta auto flash from the early 80s on my K10,20D,K7,K5.As old as the Minolta is the trigger is only 6 volts.
I have always wondered why Pentax never gives the safe trigger voltage in its specs sheets ?
11-24-2010, 05:22 PM   #3
Class A's Avatar
QuoteOriginally posted by cosmicap Quote
You'll find everything you need to know at this page about Strobe Trigger Voltages.
If you search this forum, you'll also find many threads on this topic. I once started one polling users for the highest trigger voltage their camera survived on a continues basis. It seems like Pentax DSLRs can take up to 30V, but the official value is 5V (the maximum of all Pentax flashes).
11-24-2010, 08:18 PM   #4
cosmicap's Avatar
Many thanks to you both for the help. All the info I need. Certainly glad that I asked the question!
8-)
camera, damage, dslr, flash, hv, photography, voltage
Alien Bee Flash Unit or Ring Flash Hey Elwood Photographic Technique 2 06-24-2010 07:37 AM
Fill flash for K10D with AF360 flash unit dichro1 Troubleshooting and Beginner Help 1 12-03-2009 03:08 PM
which flash unit uawpipefitter Pentax Film SLR Discussion 2 07-08-2009 10:57 AM
flash unit help, please Wombat Flashes, Lighting, and Studio 2 06-29-2008 12:51 AM
Flash Unit? Stacey Flashes, Lighting, and Studio 4 06-27-2008 01:27 AM
All times are GMT -7. The time now is 08:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
