11-26-2010, 01:43 AM   #16
QuoteOriginally posted by Hypocorism Quote
You will probably have to subject it to extreme (in a subtle way) change of temperature and or pressure, so it will gently vapourize and expel the moisture naturally.
Being in a freezing climate zone at present could be to your advantage for that, should be able to Google for a strategy.
Fwiw: I think this scenario is (partly) why camera cases are fitted with relief valves, a lot of electronic equip., hard drives etc., need re-acclimatizing to rid or avoid internal condensation.
Good luck, Mr fungus cultivator -- at worse the lens might make a good environment to grow mushrooms if you chuck in a bit of horseshit too.
.R.
LOL...well anyway, it dried up and its spotless now...haha
11-26-2010, 01:44 AM   #17
thank you for the ideas everyone...learned a great deal
02-06-2011, 09:15 AM   #18
[langtitle=cs]WR[/langtitle]
During rain (even heavy rainstorm) when not zooming and MF is locked on infinity, there is no problem. In snow, there is no problem too.
But I showered K20D + DA18-55WR few times because it smelled horrible after being in pub with smoking friends, and I noticed mysty foggy droplets inside lens. It sucks moisture inside when zooming or focusing.
So I DO NOT recommend doing that for fun and I DO recommend to put camera with lens into dry-box after. Seriously.
+ It leaves maps when dried.
Also there was a little condensation under the top LCD cover on K20D.
Both being quite disappointing.
camera, dslr, lense, photography, water
Which Lense for the K-7 SimoneDice Pentax DSLR Discussion 15 09-26-2009 03:44 AM
Noob Question Difference Between a Lense That Does Macro & A True Macro Lense Christopher M.W.T Troubleshooting and Beginner Help 16 07-19-2009 12:20 AM
Lense help.. I don't know what these are.. Orli Troubleshooting and Beginner Help 18 04-09-2009 08:01 PM
what lense is better CarlCanary Pentax SLR Lens Discussion 6 10-23-2007 10:43 AM
M-50 F 1.4 lense Stewart Minnis Pentax DSLR Discussion 13 08-15-2007 09:56 PM
All times are GMT -7. The time now is 06:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
