12-02-2010, 11:10 AM   #31
I was answering also what I understood to be the OP's follow-up question, "what lens do you recommend that captures the full 50mm" (POV, as seen in film cameras).
To which I recommended the 35/2.4 as a reasonable, and available approximation of that FOV.
12-02-2010, 11:11 AM   #32
sterretje's Avatar
You are saying that to get the same FOV as a 50mm on film that yoou need a 75mm lens on digital
I don't think I said that
Filing in the numbers we get 50 * 24 / 16 = 75mm and therefore it is said that a 50mm lens on APSc has the equivalent field of view of a 75mm lens on film
Maybe you can quote the part that causes the confusion or contains the error (or PM me if you don't want to pollute the thread).
12-02-2010, 10:15 PM   #33
Wheatfield's Avatar
Sometimes a picture is worth a dozen words....
This is a somewhat less than accurate look at what various formats will look like behind the same lens. I tried to be as close as possible, but if someone measures it out and finds it faulty, so what....
12-02-2010, 10:34 PM   #34
SpecialK's Avatar
True. Your graphic should help. Surprised this thread went on so long :-)
12-03-2010, 02:02 AM   #35
Manel Brand's Avatar
I believe it's a thousand... but I didn't count them all.
12-13-2010, 08:08 PM   #36
Excellent diagram - makes perfect sense when you see it like that.
50mm, camera, crop factor, dslr, f1.4, factor, k-x, pentax, pentax fa 50mm, photography, question
crop factor again!! adwb Photographic Technique 7 12-04-2010 06:56 PM
Crop factor demonstration. Stratman Troubleshooting and Beginner Help 19 06-25-2010 08:41 AM
Aperture x Crop Factor BBear Photographic Technique 24 07-03-2008 08:54 PM
Crop Factor Wheatfield Pentax DSLR Discussion 32 06-28-2008 01:20 AM
Crop Factor question... 35mm, DA and dslr mediaslinky Pentax SLR Lens Discussion 10 05-06-2007 11:13 AM
All times are GMT -7. The time now is 05:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
