12-02-2010, 01:39 PM - 1 Like   #1
Christine Tham's Avatar
K10D shutter issue - easy to fix?
Lately, I have noticed I have an issue pressing the shutter halfway down, and then reframing.
The shutter has a tendency to be intermittent and I'll lose the focus lock, forcing me to refocus and reframe.
Sometimes I have to do this several times in order to get a shot.
Is this an easy problem to fix? Can I do it myself? Is there a way to open up the camera, and spray contact cleaner, or something?
I prefer not to send it in for repair, as I'm trying to save up to buy a K-5.
12-02-2010, 02:01 PM   #2
Sounds like there might be something wrong with the button itself, and in this case it would have to be sent in I'd just wait it out and get the k5 when you're ready, as a k10 repair at this point is hardly even worth it.
12-02-2010, 02:14 PM   #3
You can repair the K10D later as I did. It is still a good backup camera.
12-02-2010, 02:16 PM   #4
All of that or you have the camera set on AF-C (which does not hold focus as AF-S does for recomposing).
12-02-2010, 02:39 PM   #5
A work around: Try using the AF button to focus - decouple the shutter release from the focussing
12-02-2010, 02:50 PM   #6
Thanks guys, I was hoping someone else have had a similar problem and managed to fix it by spraying contact cleaner on the shutter.
I had a similar problem on my laptop (the button in the trackpad was sticky) and managed to fix it using contact cleaner.
I am currently looking at the service manual. The top of the camera seems pretty easy to remove.
Do I need to discharge the capacitor if all I am doing is spraying contact cleaner?
12-02-2010, 03:16 PM   #7
tonyjayice's Avatar
QuoteOriginally posted by Christine Tham Quote
I have a suggestion for you ..
... Don't .. just set the camera to autofocus only when you use the AF button on the back .. and then use the shutterbutton only as a shutterbutton ..
dismantling a complex electronic thing like a DSLR is not something you want to do if you don't have a clue what to expect .. .. you might end up not having a camera at all.. ..
12-02-2010, 03:30 PM   #8
QuoteOriginally posted by tonyjayice Quote
In this case, I think I would agree (and yes, you might want to discharge the flash cap just to avoid an accident). In the Custom menu, set AF by Press Half Way, to No and make sure the AF button is enabled for AF.
12-02-2010, 05:26 PM - 1 Like   #9
LOL - you guys are such pussies!
I've just done it - it only took a few minutes.
No need to remove the entire top cover. After removing the screws, I could lift the top cover partially to expose the shutter.
No point spraying contact cleaner. The shutter is a sealed self enclosed unit so it wouldn't have made any difference.
What I did do was used a pressurised air canister to blow around the shutter button and around the shutter itself. Then closed the top cover and screwed everything back in again.
After that, there seems to be less friction activating the shutter. I took several shots and there were no issues with the shutter releasing focus lock.
Will take the camera out for a shoot this weekend and see if the problem comes back.
12-02-2010, 06:06 PM   #10
You tell 'em Christine!
Mike
12-02-2010, 06:32 PM   #11
Nowhere Matt's Avatar
I think I like her.
12-02-2010, 07:02 PM   #12
You Did ask about discharging the capacitor......
12-03-2010, 02:03 AM   #13
tonyjayice's Avatar
QuoteOriginally posted by Nowhere Matt Quote
I think I like her.
.. I understand what you mean. .. I think I do too hehe... Dibs! ..
In my litle world of delicate electronics I would rarely find myself trying something like this atleast with stuff that I really really care about, but fixing a VCR or something mor like my K2.. thats something else..
let's hope this works out for you
12-03-2010, 04:59 AM   #14
Jodokast96's Avatar
I've done it with my grip, but wouldn't have considered doing it with my K10D. Mostly due to not wanting to damage the seals, but like you said, the camera I really care about and plan to keep for for some time to come.
12-03-2010, 05:38 AM   #15
jolepp's Avatar
I think I like her.
+1 :-)
camera, dslr, issue, photography, shutter
Does K-r fimware fix the K-x firmware design issue around Drive Mode? etoprakb Pentax K-r 16 04-25-2011 05:35 PM
Even if $ is no real issue, it's not easy to replicate a Pentax system. pcarfan Pentax DSLR Discussion 86 08-14-2009 09:40 AM
Is there an easy way to fix haze in Photoshop? Hannican Digital Processing, Software, and Printing 22 06-01-2009 10:15 PM
ME Super Mirror Stuck up- easy fix?? tvfd911 Pentax Film SLR Discussion 4 04-07-2009 06:04 PM
ME super Shutter issue, help winglik Pentax Film SLR Discussion 0 03-01-2009 01:38 PM
All times are GMT -7. The time now is 07:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
