12-06-2010, 12:57 PM   #1
FHPhotographer's Avatar
AF Correction on 18-55mm?
Just picked up a 18-55WR and I was wondering if the AF correction on the K20 (and others) works on a zoom . Since the K20 can store up to 20 lens settings, is it possible to pick several of the FLs on one zoom and set the AFC for each of them, say 18, 24, 35 as though they were separate lenses... and if it's worth doing?
Brian
12-06-2010, 05:00 PM   #2
imtheguy's Avatar
The setting is keyed by the Lens ID# which should be constant regardless of zoom. So answer is no, just go for the FL you use the most or maybe an average is close.
af, af correction, camera, correction, dslr, k20, photography
K-x highlight correction LN108 Pentax DSLR Discussion 6 07-17-2010 01:48 AM
K-7 Hightlight Correction & Shadow Correction & Raw Christopher M.W.T Pentax DSLR Discussion 6 06-10-2010 03:32 PM
DA 18-55mm AL II vs DAL 18-55mm (kit lens) vs DA 18-55mm WR rustynail925 Pentax SLR Lens Discussion 10 01-08-2010 02:06 PM
Highlight correction fulcrumx29 Pentax DSLR Discussion 2 08-16-2009 12:03 PM
K7 lens correction dafiryde Pentax DSLR Discussion 8 07-16-2009 07:52 PM
All times are GMT -7. The time now is 06:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
