Originally posted by Ash Rick, I don't think you could go wrong with either camera for your applications. Even a K10D would suffice (and even be better for ISO 100 shots). Anyway the way you'd decide is by assessing your desire for camera size, video capability, weather sealing, and advanced camera customisation settings and convenience of a second e-dial. Not much to go by, but I'd suggest using the forum's side-by-side camera comparison tool in the reviews section.
I took your advice and started looking at K10's and found one...
Originally posted by paperbag846 Just one things: The k20d meters terribly with lenses lacking an A setting on the aperture ring... sounds like you have quite a few. Not sure if the KX is any better, though.
I think my K2000 metered my manual lenses a bit better, actually a ton better, just getting used to the different metering "system", the only way to describe the way the K10 meters would be consistently inconsistent.
Onwards
So I never really thought I'd consider a camera with less that 12mp until I started reading about the K10. I've only had it for a couple of days, but can tell images take less PP to look superb. But it's not without it's own odd issues... fyi- current firmware seems to be up to date, v1.31
My biggest concern, the Auto Focus struggles to say the least. By struggle, it just goes back and forth, seemingly unable to "see" the subject, when it does find the subject it focuses nicely, but this is rare and frustrating. I've tried my Tamron and F lenses all seem to have the same hunting problem.
A couple of things I've observed, the viewfinder is showing a lot of dirt and blowing doesn't remove anything, so it must be inside the prism. The mirror also looks a bit grimy.
If anyone out there has a link on "
how to" clean focusing screen and/or mirror please send it my way.
Generally, I'm very pleased with the camera, shots below I think demonstrates that the camera can indeed focus using an AF, Takumar and M lens, so I'm hoping it's just a minor issue... Thanks, Rick
Tamron 28-105 from DNG
Super-Takumar 50/1.4 from DNG
M 50/1.7 this is a straight out of camera JPEG with very little PP
All processed using Faststone...
