12-11-2010, 01:56 PM   #16
QuoteOriginally posted by mojoe_24 Quote
Yeah, I originally was thinking about picking that package up, but most people say that the lens isn't great.
There's nothing wrong with that lens. People just love to trash on it since the 55-300 came out. The 55-300 may be a little better but the 50-200 got tons of positive recommendations and good responses in the past. The 50-200 is considerably less expensive and is no worse than the kit lens in terms of quality. If you don't want to spend the money on a 55-300, then a 50-200mm is worth it if you can afford it.
12-11-2010, 06:08 PM   #17
mojoe_24's Avatar
I'll have to try to figure out what makes the most since financially. It really annoys me that the white is quite a bit more than the black when it comes to the kits with multiple lenses.
12-11-2010, 07:31 PM   #18
SpecialK's Avatar
The 50-200 is inexpensive and compact. It did not measure up well when I went from the 6MP K100D to the 14.6 MP K20D, however. The 55-300 is just noticeably better. The 50-200 and cash got traded for something else, and I rarely use the 55-300 anymore (have to justify the other recent lenses)...
12-11-2010, 10:48 PM   #19
Well the white K-x with 18-55 and 50-200 kit is actually $10 cheaper than the equivalent black.
White K-x 18-55 + 50-200 kit Google Price search
Black K-x 18-55 + 50-200 kit Google Price search
12-11-2010, 10:56 PM   #20
mojoe_24's Avatar
I've never heard of BuyDig. Hmm, red for 540 and white for 570
12-11-2010, 11:59 PM   #21
LCD protector
ACMAXX HARD LCD PROTECTOR
I am using it with my K-7 for a year, I can definitely recommend it.
12-12-2010, 11:16 AM   #22
mojoe_24's Avatar
What SD card would be best to get? Something like a Transcend class 10 or Sandisk Extreme III? Also, does a larger capacity cause problems? Would it be better to have two 8gb cards instead of one 16gb card?
12-12-2010, 11:41 AM   #23
jolepp's Avatar
With current prices I suppose I would get two 8G class 10 Transcends, it seems to be an o.k. brand, yet the price is good. With any brand it is a good idea to test them thoroughly before putting them to use (a couple of cycles with something like h2testw should detect a defective one).
12-12-2010, 12:32 PM   #24
mojoe_24's Avatar
Having two is better than having 1 larger one?
12-12-2010, 12:45 PM   #25
jolepp's Avatar
In case there is a problem with one you should still be able to use the other at least. Also, having more than one card means not having all your eggs in one basket, so to speak.
12-12-2010, 05:15 PM   #26
mojoe_24's Avatar
That's true.
12-20-2010, 09:37 AM   #27
mojoe_24's Avatar
Would I need to buy a bag right away? Trying to decide on the color and I'm stuck between teh baby-ish blue and the white. If I need to buy a bag right away I'll probably buy the blue because it's $30 cheaper.
12-20-2010, 11:07 AM   #28
jolepp's Avatar
A bag is good for protection (knocks, elements) and convenience. It may be enough for neat, organized storage too (until there is more gear than you can carry at one time ;-) IMO bags are something you should get hands-on with if possible before buying. Also some experience using the camera should help to pick one that is practical and convenient for you so waiting a bit might help to make a better initial choice. OTOH a bag that holds the camera+lens, 1-2 extra lenses, hoods, and some basic supplies such a spare battery and a cleaning kit (e.g. lowepro nova 160 aw) is good to have even if you need a bigger one for storage or carrying a more comprehensive kit, so something like that should be a good choice to get started with. A padded bag with movable partitions to put the bigger items into and pockets for the smaller stuff is good for keeping the gear protected and organized/conveniently accessible. As color choices go that is matter of personal preference, but I would avoid white as it may get not-so-good-looking in a hurry (and one point of having a bag is having less to worry about).
12-20-2010, 03:58 PM   #29
mojoe_24's Avatar
Ended up buying the $540 kit with the 55-200mm lens. Might have to put off buying the bag for a couple weeks. Would being out during that time do any harm to the camera?
12-21-2010, 10:09 AM   #30
jolepp's Avatar
As long as you protect it from knocks, keep it dry and reasonably free of dust it should be fine. With a bag this is just easier to do as is carrying what you need. In case you take it out where it is below freezing or so it may be a good idea to seal the camera and lens(es) into a ziplock bag before getting back inside and let them warm before opening the bag to avoid water condensing on/in them.
camera, dslr, photography
Help picking a carrier for iPhone pcarfan General Talk 39 01-12-2011 08:18 PM
Help picking up a setup! R3dux Pentax SLR Lens Discussion 18 11-01-2010 09:19 AM
Need help picking a wide angle TOUGEFC Pentax SLR Lens Discussion 16 04-14-2010 03:24 PM
I need help picking a flash perception-of-light Flashes, Lighting, and Studio 5 02-19-2010 03:35 PM
Need help picking a wide angle lense Moggman Pentax SLR Lens Discussion 21 03-14-2008 06:16 PM
All times are GMT -7. The time now is 03:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
