Originally posted by runjmb My only complaint is the lack of blue sky in some of my pictures. When I shoot a pic with the sky in the background, I am getting a white sky. I tried every setting on the AWB and got the same results. I found the situation is improved if I stop down, but its still not perfect. Is there anyway to get a bluer sky?
What colour sky do you get if you just take a picture of the sky with nothing else in the shot?
If blue, then I fear the problem is simply that when the sky is the background it is very over exposed - at a guess you're exposing for the foreground, but the sky is much brighter.
This is a tricky problem to overcome if there are large brightness differences between parts of your photo.
You can reduce the brightness of the sky by using a graduated neutral density filter, but this won't always work, since often foreground detail protrudes into the bright area.
Usually better to expose more for the sky (by stopping down you're effectively doing this), then carefully selectively increase the brightness (on the computer) of what will then be underexposed foreground. This can often give good results, whereas severe overexposure ensures that no detail is recoverable.
There's no single perfect answer to this one, sadly. Shooting RAW will tip the odds a bit in your favour, since you get all the data recorded by the sensor, but once detail is burnt out, it's gone for good.
