Originally posted by DragonLord My interpretation of the manual is that only auto-aperture capability is needed for multi-segment metering. This has nothing to do with the brand of the lens.
--DragonLord
That is correct.
For all those who question whether they are getting matrix metering with Non Auto aperture lenses, there are a couple of simple tests you can try.
The center weighted metering will respond to a bright light located off the center of the screen, so using both matrix and center weighted settings, place a light against a uniform colored wall at half way between the center of the viewfinder and one edge. (note it is best to use a tripod for this to gaurantee framing does not change) You will find center weighted metering will tend to underexpose the wall and expose more correctly for the light, matrix metering will recognixe the bright spot and let it burn out a little, to get a better average exposure of the wall.
If there is no change between the greyscale value at the middle of the frame between the two shots you are in center ewighted mode, regardless of what the EXIF says or the mode switch is set to.
