Originally posted by gkamieneski I purchased some Sony Cycle Energy NiMH batteries with charger and I already had some Duracell branded Enerloops.
Both sets of batteries charge up fine with the Sony Charger to 1.34 volts when measured with a multimeter. The Duracells work well and hold their charge well. The Sony's however register empty on the battery meter of the K-x. When I check them with the multimeter they still show 1.32 volts. I have never dared to use these batteries because of what they register on the K-x meter.
What could be causing the meter to register this way, or do you think the batteries are defective?
OK most NiMH including LSD type - like eneloop, Duracell Pre-Charged and Sony Cycle-Energy etc - come "hot off the charger", as if it were, at about 1.45-1.47V - after about a day or so they do settle to about 1.39V for LSDs
- in fact my eneloops which were charged 30 days ago still measure 1.39V open circuit (no load).
Mine is a mere cheapo digital MM which has been pretty accurate.
Of course your multi-meter may give different absolute readings.
But with both your readings and the K-x actions -
I would suspect the charging of the batteries could be a possible issue
or one or more of the new batteries is faulty.
Have you tried charging your new Sony Cycle-Energy in the charger you've used previously for the Duracell Pre-Charged?
Also are all 4 of the new Cycle-Energy in good condition?
as a single under-par cell can bring the whole set down.
Here's a crude elimination test -
use 3 of the good Duracell Pre-Charged -
try the new Cycle-Energy one at a time
and see if all 4 in turn manage to power the K-x -
if any show lower than normal levels then I would suspect those.
BTW - if the Sony Cycle-Energy have white top (surrounding the positive tip) and marked made in Japan on the batteries - then those also are confirmed re-badged eneloops.
