12-18-2010, 09:37 PM   #1
rrwilliams64's Avatar
K-x shutter actuation button sticking
I have a K-x, less than 4K actuations, out of warranty by a month.....problem i'm having is the shutter actuation button is "sticking" all the way down occasionally. Does this sporadically...half press to focus/compose, fully depress to take the pic, then it... stays there. Seems to lack that "tension" the shutter actuation buttion should have A little jiggling or a firm press will "release" it, but its quite bothersome and growing progressively more frequent. And when its "stucK down, you can do nothing, camera is 'dead' til you "unstick" it. Note- it is indeed a mechanical issue as you can see the shutter button stuck down in the depresed position til you tap/jiggle it to release it
Nothing ever spilt, camera has been treated well, no exposure to moisture, elements, etc etc. (as I know, my first question would be 'did ya spill something on it or is something stuck in there?')
Short of sending it in to Pentax for a fix, any suggestions? And, if Pentax-bound, would this be a costly repair? New to the model and Pentax in general, looking for some common sense input.
thnx in advance
12-18-2010, 10:19 PM   #2
hcc
hcc's Avatar
Sorry to hear your problem.
You may wish to check also the following threads in this forums:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/95814-k-x-sticky-s...ghlight=sticky
https://www.pentaxforums.com/forums/pentax-film-slr-discussion/108231-sticky-...ghlight=sticky
There might be some good suggestions and hints. A user (Wildlifephotog) suggested:
"The spring that is under the silver button is not very strong. Just the normal oils and grime that get on your fingers is transfered down along the sides of the button.
I've had to clean both my DS and K200D. I use contact cleaner sprayed on a q-tip to let it run down the sides of the button. I then work the button for a minute or so. This usually gets it clean so it doesn't want to stick at half press."
Hope that you can solve your problem....
12-20-2010, 07:51 PM   #3
QuoteOriginally posted by hcc Quote
...I've had to clean both my DS and K200D. I use contact cleaner sprayed on a q-tip to let it run down the sides of the button. I then work the button for a minute or so. This usually gets it clean so it doesn't want to stick at half press."
not to be overly specific, but allow enough liquid contact cleaner to actually run down 'round the sides of the button? Danger of too much? Perhaps an ambiguous qstn, and i realize the need to lubricate the spring/free up any dust and/or obstruction, but what.....a few drops? . i was thinking of spraying the contact cleaner into a dropper bottle and letting a single drop down around the base of the button. I realize no right or wrong here (or perhaps there is!!!!)...just wanna proceed cautiously.
12-21-2010, 10:45 AM   #4
did the trick... few very light drops....worked arond the base of the buttom.....clilcked repeatedly, still stuck now and again, but improving
Next day....bingo.
Thnx for the great tip HCC
actuation, button, camera, dslr, k-x, pentax, photography, press, shutter, til
Shutter Actuation Count for K7 Jatcat Troubleshooting and Beginner Help 2 05-27-2010 04:08 AM
New K20d Shutter Actuation Count Discrepancy harleynitelite Pentax DSLR Discussion 8 10-15-2009 12:46 PM
ME Super shutter button sticking? oinkely Film SLRs and Compact Film Cameras 3 03-01-2009 01:51 PM
My 20,000th Actuation of the shutter konraDarnok Post Your Photos! 8 07-07-2008 11:26 AM
K20D Shutter Actuation Help! VHDEL Pentax DSLR Discussion 5 03-14-2008 04:52 PM
All times are GMT -7. The time now is 07:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
