12-20-2010, 12:49 PM   #1
Used k7, This Look Right?
I purchased a used k7 with 1,500 clicks, when testing it out at iso 200 the image crops look slightly more soft and noisy compared to my k10d and k-x.
k7 iso 200 f 2.8 1/100 w flash Fa 43
Is this what the k7 sensor produces or is this a bad camera
Thanks again
12-20-2010, 01:03 PM   #2
ambienthousewife's Avatar
Nasty doughnut shapes to the out of focus highlights, but that is a lens issue, not camera I think? Looks like the results you would get from a mirror lens.
12-20-2010, 01:52 PM   #3
kiwi_jono's Avatar
I can't see the noise? There is quite a bit of dust on the table which you can tell is dust by the focus band.
12-20-2010, 02:37 PM   #4
Looks like a simple back focus to me. And a severely dusty table.
12-20-2010, 04:03 PM   #5
KxBlaze's Avatar
It doesn't look like there is anything wrong with the camera but do think that some better test photos would give us a better idea. Maybe a test subject on a clean table.
12-20-2010, 05:16 PM   #6
Some more shots I find off for iso 200;;; 100% Crops
PENTAX K-7  Photo
PENTAX K-7  Photo
12-20-2010, 10:01 PM   #7
1. What part of the full image are the crops? Helps if you post the whole image and then a crop.
2. They look underexposed by 1 or 2 stops. Try posting a properly exposed image.
3. I'd expect the K7 to be noisier than the Kx, although it should be hard to notice at iso 100-200.
12-21-2010, 04:11 PM   #8
Ex Finn.'s Avatar
Sure does look under exposed, nice "grain" how ever.
12-21-2010, 04:24 PM   #9
eccs19's Avatar
My K7, if I underexpose, that's exactly what I get. If I'm properly exposed, or a bit on the plus side, it's all good. I've had a few ISO 800 with no noise, as it was exposed perfect. You just need to get used to how that camera works.
12-21-2010, 04:25 PM   #10
Wheatfield's Avatar
Try shooting correct exposures rather than a couple of stops under. Your situation will improve dramatically.
camera, dslr, iso, k7, look, photography
All times are GMT -7. The time now is 02:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
