12-23-2010, 06:32 AM   #1
*ist DL firmware upgrade failure
Not being very computer savvy, I brought me K20D and *ist DL to my local independent camera store and asked them to do a firmware upgrade. They logged into the Pentax site and were able to upgrade the K20D, but could not get the firmware to load on the *ist DL. They tried different SD cards and changed to fresh batteries to no avail.
Does anyone have a suggestion on how to proceed? I saved the SD card that has the dwnloaded upgrades, but I still cvannot get the camera to accept the up grades.
Thanks for any help,
Larry in Chapel Hill
12-23-2010, 04:55 PM   #2
Ole
Ole's Avatar
First thing to check is that you use a first generation SD card. Without the upgrade, the camera cannot read SDHC cards.
12-23-2010, 08:29 PM   #3
It worked for me on my DL. I used the card that Pentax recommended. I can't remember, but I think it was 16 or 32Meg (not Gig). I would try an old card like a 32Meg. Follow the instructions on the Pentax website to copy the file to the card. Make sure your batteries are good, and do the update.
12-27-2010, 04:07 AM   #4
QuoteOriginally posted by Ole Quote
Is the camera dead? If not, try formatting the card in the camera and then copy the update on and so on - make sure you charge the battery first. I have a feeling some SD-only devices can format and use SDHC cards but they only format and use the first 2GB - SDHC extended the size up to 32GB.
12-28-2010, 02:51 AM   #5
Thanks to all for the help.
I tried the upgrade myself using a 256 meg card and everything loaded correctly. Now I can use a 4GB card.
LD50
*ist, camera, dl, dslr, firmware, k20d, photography, sd
Firmware upgrade FishrOfGrizz Pentax DSLR Discussion 4 10-27-2010 09:38 PM
Can't upgrade my firmware jupzchris Pentax DSLR Discussion 9 07-30-2010 07:37 PM
Firmware Upgrade gumpa Pentax DSLR Discussion 2 03-12-2009 01:18 PM
How to Upgrade Firmware? rzarbo Pentax DSLR Discussion 13 01-25-2008 04:19 PM
Have a k10d firmware update failure ,what can i do now? wsajian Pentax DSLR Discussion 40 08-05-2007 03:33 PM
All times are GMT -7. The time now is 02:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
