Originally posted by armrob
I got it on ebay so no warranty. and i don't know if the seller knew about the problem or not. it seems like its unable for some reason to save the picture.
so when i go to review the pictures, there is always one that says "unable to read file". the file is also unable to be read when I put the sd card on the computer.
anyway, I will play with it for a while, if it stays the same, i'll get back to a Canon.
thanks,
Sounds to me as an read/write problem.
What kind of SD-card (brand/model) did you use?
Did you format the card before use in the camera?
Are you sure your memory card is not on "locked" position?
By the way, the same problem can happen to an used Canon, Nikon or whatever, so changing brands will not bring you much. Try to figure out and isolate the problem.
cheers,
d
