12-26-2010, 01:02 AM   #1
K-x refuses to capture
Hello again,
I'm still learning the K-x since I've only had it for almost one week.
I've noticed that sometimes it will focus, but without the beep and then it wont capture anything. The information line on the bottom of the viewfinder, it's blinking like crazy.
What does this mean? I have read the manual but couldn't find anything about this particular problem, unless I just missed it.
Anyone got an idea?
12-26-2010, 04:07 AM   #2
This is off the top of my head, but it sounds to me like you're exposure isn't set correctly and out of range of what the camera deems acceptable. I'm a newbie here as well, so I hope I've got all the terminology correct.
12-26-2010, 04:33 AM   #3
jolepp's Avatar
If it doesn't beep (and the hexagon in the viewfinder is not solid) then it is not satisfied it has managed to focus. This is prone to happen in low light or if there is not enough contrast for the AF sensor (e.g. trying to focus on a blank wall). I suspect it might blink the viewfinder display when it is unable to set "reasonable" parameters in one of the auto-modes, such as when light is not good, flash is not in use, ISO is set low and this would result in a very long exposure.
12-26-2010, 07:26 AM   #4
Try turning of the lens autofocus switch and see if it captures anything. Can you shoot anything in daylight? Maybe you are using single AF point and have selected the far edge point and the camera is finding it difficult to focus on that point.
12-26-2010, 07:37 AM   #5
Hey, thanks all!
It sounds probable, since it does it in very low light and I guess, not good enough settings.
So it's all normal then, thank you guys!
camera, dslr, k-x, photography
WTF? K100D now refuses to recognize non-DA lenses. mulanrouge Troubleshooting and Beginner Help 11 09-28-2009 01:03 PM
C1 (Capture One) v4.7 was released deejjjaaaa Digital Processing, Software, and Printing 4 04-02-2009 05:49 PM
Capture NX2 Photo Tramp Digital Processing, Software, and Printing 0 10-11-2008 12:09 PM
Capture one lequynorm Digital Processing, Software, and Printing 2 09-19-2008 09:06 AM
First macro capture SouthShoreRob Post Your Photos! 13 07-13-2008 12:03 PM
All times are GMT -7. The time now is 10:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
