12-26-2010, 10:42 PM   #1
Slow Pentax K-7 buffer and write times
I have very slow write times to a class 6 Sandisk 8GB card. I upgraded from a class 4 PNY 4GB card and the write time didn't improve. In situations where I need fast response, this is extremely frustrating and I'm missing many shots waiting on the camera. Have firmware 1.10.
Despite my efforts in adjusting settings which might affect write time, nothing seems to speed up the process. I changed the file size from 14 to 10MB - no difference. The following are real time tests I did this evening. When testing the camera I switched to manual focus - hence no focus hunt time. These are the results.
14 MB jpeg. Aperture priority. Manual focus - iso 3200. Shutter speed averaging around 200th of a second.
Hi drive mode - initial burst of 4 frames in perhaps two seconds. Then each additional shot came every 2.5 to 3 seconds. In sixty seconds I was able to shoot 22 frames in 60 seconds so my shot to shot time average came down to 2.7 seconds between images.
Lo drive mode - disabled shake reduction, disabled high ISO noise reduction, disabled copyright and author information. Same results - I made these changes one by one and tested the shot to shot time. The only one that seemed to marginally speed up the camera was disabling the high ISO noise reduction, it may have shaved half a second off the write time after the initial burst of 4 frames. 23 frames in 60 seconds. Shot to shot time average 2.6 seconds between images. 1st four images in rapid succession then the wait.
Single shot mode - same items disabled as above. Able to get off 26 frames in 60 seconds pushing the shutter release constantly and as fast as I could. Shot to shot time average 2.3 seconds between images. 1st four images in rapid succession then the wait.
Suggestions? Is my camera defective? I suppose I should drag the K10 out of the closet and try these tests. I never seemed frustrated with its shot to shot performance and didn't feel like I was always missing key photos. Thanks for any help!
12-26-2010, 10:53 PM   #2
sterretje's Avatar
Are you using the latest firmware. I seem to remember that this was an issue with the initial firmware release for the K7, but I might be mistaken. Just do a search here
12-26-2010, 10:55 PM   #3
Yeah I have 1.10 which is the latest. Thanks though!
12-27-2010, 12:13 AM   #4
Ash
Community Manager
Ash's Avatar
Check your lens correction feature settings on the camera - this is the typical culprit. Turning the advanced features off (if not needed) will significantly speed up processing times. The transfer rate should not change - it should keep up with the continuous shooting.
12-27-2010, 02:45 AM   #5
Solved - Turn Off The Lens Correction.
Thanks Ash. The lens correction was indeed the culprit. I found an earlier thread just before I got your reply. It's not one of the features which shows up on the first level menu with a check beside it, so I hadn't even thought to look at its status.
I would never recommend turning it on unless perhaps you are doing architectural shots on a tripod and can't do any post processing correction. It probably doesn't do anything better that what I regularly do for barrel distortion in PS. Months beating my head against the wall and I'd searched the forum before and hadn't come across the solution...
12-27-2010, 05:47 AM - 1 Like   #6
Ash
Community Manager
Ash's Avatar
Good to hear.
Enjoy your newfound speed in burst mode.
12-27-2010, 08:34 AM   #7
Santa Baby
This was so exciting, I jumped out of bed after a few hours sleep - it's Christmas morning and I know I heard something on the rooftop! I'll probably stay away from the burst modes for the most part but thank God it's really there when you need it.
My digital backlog is already a mountain. The time factor with digital (for me considering post processing, organization etc.) is almost the same as film. Thankfully once you have your equipment, the financial outlay is much less, just keep buying more hard drives and backup drives. Where's my $100 indestructible Petabyte hard drive?
camera, dslr, focus, frames, images, iso, mode, photography, reduction, shot, time, write
Pentax K-5 - buffer limit problem !!! gubak Pentax K-5 19 11-22-2010 09:19 PM
Help me pentax k20d 21fps buffer illimited? MISTER_MORRISS Pentax News and Rumors 7 05-12-2008 05:13 AM
Pentax k110d Read/Write Delay? bfrikken Pentax DSLR Discussion 1 04-30-2008 10:01 AM
Buffer Write Speed of the K10d ruemiser Pentax DSLR Discussion 5 12-30-2007 09:41 AM
Time Exposure - Bulb setting - Read write times Vatis Pentax DSLR Discussion 7 09-05-2007 07:38 AM
All times are GMT -7. The time now is 03:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
