12-29-2010, 08:53 AM   #1
K-x and Raynox DCR-250
Dear All,
I am a newbie to DSLR (My panasonic tz-7 was a great compact solution) and I want to buy k-x in order to photo flower/insect macro. The kit I have in mind include the 18-55 und 50-200 lenses. None of these lenses is for macro but I liked the Raynox DCR-250 solution.
Therefore, can someone please explain me how it is connected to the 18-55 lens (photos will be welcome) and how to use it.
Furthermore, any idea for a cheap solution for macro lens?
Thanks a lot&happy new year,
Ashz
12-29-2010, 09:13 AM   #2
KxBlaze's Avatar
The Raynox attaches like a lens cap would. You pinch it and when you release it there are 2 tabs that "grab" onto the filter threads.
Shooting with the Raynox can be a little tricky. I have had mine for a while but have not really tried to use it too much. The DOF is very small (there might be a way to make it larger), and you have to be pretty close to the subject, but I guess most macros are like that.
As for other options besides getting a true macro lens, you could get a reversing ring and reverse attach another lens, or get an extension tube. I have not tried reversing a lens but an extension tube works pretty good.
12-29-2010, 09:58 AM   #3
RioRico's Avatar
The DCR-250 has greater magnification, thinner DOF, and a closer working distance than the DCR-150. So you might consider the -150 as an easier option. The Raynox "universal mount" is a pinch-on device that fits 52-69mm front-thread lenses (the DA18-55 has a 52mm thread) and can be forced onto a 49mm thread -- although I usually use a 49-46mm step-down ring to mount my -250 onto my Pentax 49mm-thread lenses.
Lens reversal is powerful and tricky. Powerful, because by reverse-stacking one lens onto another, you can gain great magnification. Tricky, because any reversed lens setup has a very close working distance -- 45.5mm, under two inches. Whether a lens is reverse-stacked using a thread-reversal ring, or just flipped using a mount-reversal ring, the working distance is that same wee little bit. The reversed lens MUST have a manual aperture ring.
Extension (tubes and/or bellows) can be added to any manual-aperture lens. Some camera lenses will not give a flat-field rendering with edge-to-edge sharpness, so I like inexpensive enlarger lenses on extension. Only fairly expensive and hard-to find macro tubes, or modified teleconverters, will allow auto-aperture lenses to work with auto-aperture control. Most tube and bellows work well with available or controlled light, but are tricky with flash.
A Raynox allows full auto operation of a lens. It is simpler than cheaper methods, and cheaper than dedicated macro lenses. A Raynox is a good plaace to staart.
camera, dcr-250, dslr, k-x, lens, lenses, macro, photography, raynox, solution
Any thoughts on the Raynox DCR 250 eaglem Troubleshooting and Beginner Help 27 04-19-2015 06:31 PM
Raynox DCR-250 Naturenut Pentax SLR Lens Discussion 7 07-12-2010 08:56 AM
Advice please Raynox DCR 250 - US Seller kev.pride Pentax SLR Lens Discussion 5 03-16-2009 08:58 AM
Anyone with Raynox DCR-250 and 62mm filter lens? pentagor Pentax Camera and Field Accessories 2 12-21-2008 12:38 PM
All times are GMT -7. The time now is 05:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
