12-31-2010, 11:46 AM   #1
K10D & SMC Pentax-A Zoom 1:4, 70-210mm
I have a pentax k10d and an smc pentax-a zoom lens. I need some advice on how to use the lens with the camera. The lens does not have the electronic features that work with the camera body. So I need to know how to utilize the electronic settings on the camera to properly use the lens. What settings do I need to use on the lens and what electronic settings do I use on the camera? Thank you for any help that you can offer.
12-31-2010, 12:28 PM   #2
Make sure the lens aperture ring is locked into the A position and you should be able to use it just as any other lens, minus the Auto Focus. If you are seeing F-- where the aperture should be on the top screen, make sure you have the custom menu setting, Use Aperture Ring (or something like that) set to Permitted. To get you started, set your camera to M mode, pick an aperture, focus, press the Green button, and shoot. The Green button will center the exposure and you can adjust from there to either under or over expose (but don't press the green button again after you've made your adjustments).
12-31-2010, 12:49 PM   #3
Ivan Glisin's Avatar
QuoteOriginally posted by groth6654 Quote
Set any Pentax-A lens to the A position (press the button to get there from f/22).
Set AF selector to MF (manual focus). You could leave it in AF but camera won't release shutter if focus is not confirmed. For now just switch to MF.
Use the lens in any mode you like. There is no difference in functionality compared to F, FA or DA lenses, except for auto focus. Wireless flash and P-TTL flash also works fine with Pentax-A lenses.
12-31-2010, 01:18 PM   #4
Thank you Jeff and Ivan. I followed both of your suggestions and I have been successful getting it to work, however I have found that even in the Manual focus mode the shutter won't always release. I have had to focus and re-focus a couple of times in order to get the shutter to release. This is new to me so I guess that I will have to read up on it too. Your advise is greatly appreciated. Thank you.
Bill
12-31-2010, 01:49 PM   #5
The K10d is capable of Catch In Focus (focus trap) with these lenses but I don't remember if you have to turn it on or not (in the custom menu). In AF-S, if you hold the shutter release while turning the focus ring, the shutter will snap when it detects focus. This does not work with all lenses on the K10d (DA*SDM lenses for instance) but with manual A/M type lenses, it should. In AF-C and MF however, the shutter should trip regardless of focus. At least that's the way I remember it being.
12-31-2010, 03:04 PM   #6
This a catch in focus/focus trap photo taken with the SMC Pentax-A Zoom 1:4, 70-210mm. I have had two copys and have sold both but would buy again if the price was right.
Frank
12-31-2010, 03:29 PM   #7
That's strange. Looks like you are not in MF mode and camera is expecting catch focus. Are you sure autofocus selector is in MF? If it is, put autofocus lens and try to see if AF lens focuses in MF mode, perhaps the AF mode selector is broken?
I have double checked with my K10D in MF mode and I can always release shutter with MF lenses, even with the cap on. My *istDS does the same.
12-31-2010, 06:23 PM   #8
ryan s's Avatar
It's happened a few times with my K10D over the years...don't know why, though. Some say one of the e-dials gets stuck between positions and the camera can't decide what to do. A quick reset of the power switch solves it, however inconvenient it is.
In my case, even a refocus wouldn't get the shutter to release...so that's a weird issue. Maybe flick the AF switch to AF.S then back to MF?
01-01-2011, 09:34 AM   #9
QuoteOriginally posted by ryan s Quote
I guess that's the best thing to do. OP's description indicates camera does not read auto focus mode selector as in MF position, so flicking it back and forth a few times may actually help.
BTW, I personally never liked auto focus mode and metering mode levers on K10D. There are too soft with no distinct "clicks" between the positions, so I always double check if camera is really in the mode I want it to be.
01-02-2011, 02:34 PM   #10
Thanks again. Your suggestions and advice were helpful. I am new at using this camera. What it boiled down to is my lack of understanding the various functions of the camera. I am getting better at using the camera thanks to your help.
camera, dslr, k10d, lens, pentax-a, photography, settings, smc, smc pentax-a
SMC Pentax-A Zoom 70-210mm f4 timstone Pentax SLR Lens Discussion 25 04-19-2011 12:23 AM
For Sale - Sold: Pentax SMC-A 70-210mm f4 Macro zoom; Pentax A3000 film SLR; Vivitar 28-210mm z NeverSatisfied Sold Items 9 05-14-2010 01:37 PM
For Sale - Sold: [Worldwide] SMC PENTAX-F ZOOM 70-210mm 1:4-5.6 Curbster54 Sold Items 2 02-15-2010 05:14 PM
Advice on pricing smc PENTAX-A ZOOM 1:3.5~4.5 35~210mm. Curbster54 Pentax SLR Lens Discussion 0 04-13-2008 05:19 PM
Test shots with my SMC Pentax A 1:4 70-210mm zoom Darius4522 Pentax SLR Lens Discussion 2 10-03-2007 09:23 PM
All times are GMT -7. The time now is 01:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
