Originally posted by noblepa I don't get the wailing and gnashing of teeth over Pentax' lack of a FF dslr, either.
Well, one of the reasons would be a bigger, clearer viewfinder.
Quote: I just checked B & H. The D3 is $4,999. The 5D is $2,999. The EOS-1DS is $5,999 (bodies only).
Right now, we have some really great, affordable, 10MP APS-C dslrs to choose from. Unless and until someone makes a FF dslr under $1,000, Pentax is safe, IMHO.
Agreed that Pentax is not currently in this market.
Quote: I think that what may happen is that APC-C will become the standard for serious amatuers just as 35mm did and FF will replace medium format film cameras as the format of choice for pros.
I believe that full-frame will become the standard, and APS-C will be relegated to entry-level only. The reason is because they're using the same 35mm mounts (except Olympus) and there is an understanding that lenses used on these mounts can cover an image circle large enough for 24x36mm. Simple.
Quote: As for getting used to the "crop factor", I think that is a non-issue.
For you, that's fine. I never owned a 35mm SLR until after I bought my DSLR so it wasn't an adjustment factor - it was (and is) more about using lenses designed for one purpose in a different way. For example, I'm now shooting 28mm lenses in the same way as 'normal' lenses previously. A 28mm lens isn't designed the same (as far as distortion, CA, bokeh, sharpness, etc.) as a 50mm lens, so this is where many people have problems.
Quote: To me, its like the uproar over the conversion to metric measure.
I didn't know they switched to metric in Ohio!
Quote: As some else suggested, FF cameras are going to be larger and heavier, as are the lenses. Most consumers will prefer the smaller, lighter (not to mention less expensive) cameras.
I don't really see this, either - the K10 is much bigger than the *ist D. Consumers don't always demand smaller.
This is also where I complain that Pentax is missing the point - if they want to keep on with the small-size sensor, at least bring about some innovative lenses for the format! How cool would an 80-200
f/2 lens be?!? They would sell every single one.
But Pentax is mired in thinking that a 50-135/2.8 somehow replaces an 80-200. This is just not so.
Quote: Finally, APS-C sensor development isn't standing still. There are already 12MP sensors. Its only a matter of time before someone develops a 16 or 18MP sensor in the APS-C format. By then, FF sensors will be at 24 or 30MP.
God help us! The 10MP sensors are already too noisy at ISO 400, I can't imagine what an 18MP sensor would be. The few Nikon D300 and Sony A700 samples I've seen employ noise reduction about which I'm still uneasy.
YMMV.
