01-02-2011, 06:05 PM   #1
Problem with Tamron Lens
I have a K2000 and it was working fine last time I used it. I spent some time today "trying to learn the camera" now the camera will not work with the lens. When I hit the shutter it shows all yellow and then the photo shows all black. Oh my god what have I done. I hope it is just a setting since I have not dropped anything. Also the camera works with the original Pentax stock lens.
01-02-2011, 06:37 PM   #2
IF the camera works with the Pentax kit lens, as you say, Stock lens, then the issue is not likely to be the camera. That leaves 2 things. The Tamron lens or the card. Simple things to try are reformatting the card, make sure the lens is seated properly, try cleaning the contacts on both the camera and the lens. Do these one at a time however so if any of it solves your problem, you'll know what the culprit was.
01-02-2011, 08:14 PM   #3
EdwardConde's Avatar
I have a Tamron lens, one thing I noticed is at it has to be set on auto on the lens itself in order to work on my kx. I think this is because the lens i have works on film pentax slrs and dslrs. I have not experienced what you described with my Tamron.
01-02-2011, 10:24 PM   #4
SpecialK's Avatar
it shows all yellow
What is "it"?
and...
The LCD is black, your computer monitor is black, or the image is total black with no detail at all?
What mode are you shooting in?
01-03-2011, 11:19 AM   #5
I have found the answer to this problem. I am unable to figure out how to delete my post. Thank you everyone for your replies.
01-06-2011, 11:02 PM   #6
Whats the answer?
camera, dslr, lens, photography, time
Do I have a problem with Tamron 10-24? victordeamorin Troubleshooting and Beginner Help 6 11-20-2010 01:03 PM
Is this a problem? Tamron 70-200mm 2.8 ottersden Pentax SLR Lens Discussion 2 12-09-2009 07:36 PM
Tamron 28-75 f/2.8 over exposure problem Sew-Classic Pentax SLR Lens Discussion 13 10-22-2009 02:49 PM
K100d-s and Tamron problem... mozo Pentax DSLR Discussion 2 08-04-2008 01:32 PM
Tamron P/ka mount problem vanchaz2002 Pentax SLR Lens Discussion 4 07-11-2008 01:56 PM
All times are GMT -7. The time now is 12:59 AM. | See also: NikonForums.com, part of our network of photo forums!
