10-05-2007, 05:58 AM   #16
Lowell Goudge's Avatar
to answer the original question,
the rule of thumb is (for full frame sensors or 35mm film) 1/focal length, based upon someone's consideration a long tiome ago of the acceptable influence of camera shake, on a small print, when you view the entire frame.
for ASP-C yes, you need to adjust this for the crop factor, and themanual is correct, multiply focal length by 1.5 for no shake reduction.
Here is the important point. You also need to adjust it the same way, for enlargements.
If you intend to blow up past (lets say 4" x 6") you would need to also adjust the same way for the enlargement factor.
If you are going to make an 11 x 17 print, since this is roughlt a 3 times blow up you may want 3 times faster shutter speed.
Obviously every one's technique and stability are a little different, and time to compose shots also can allow you to "cheat" a little, but for general walk around shots, where time to compose, relax etc is minimum, the rule is pretty good.
camera, dslr, k10d, length, lens, person, photography, rule, sr
For Sale - Sold: K10D w/ 3 Extra Batteries, DVD Tutorial, K10D Book! ksignorini Sold Items 2 08-28-2008 08:24 PM
For Sale - Sold: FS: New K10D battery, K10D book sven Sold Items 2 12-17-2007 12:42 AM
All times are GMT -7. The time now is 03:51 AM. | See also: NikonForums.com, part of our network of photo forums!
