01-09-2011, 11:37 AM   #1
Lowell Goudge's Avatar
Image processor which mimics camera settings
I am posting this because I cannot find now the thread where a question was asked
Someone had asked if there was any RAW converter that mimiked the camera settings
From memory the latest version of pentax photo laboratory does this
01-09-2011, 09:14 PM   #2
lightroom, i use the olympus E5 preset for my sony raw... gives me a color tone i prefer over the sony jpeg engine.
01-10-2011, 12:18 AM   #3
I can confirm this -
the Lab part of the Pentax DCU (Digital Camera Utility) default is "Camera setting" -
which basically gives the same rendering as the paired JPG if taken as RAW+JPG.
I have pairs of DNG+JPG - this is a pair I took trying to see the difference other RAW processors treated the DNG file with the K-x Highlight Correction On (this feature caused some some RAW processors not to render the RAW file correctly).
JPG - IMGP3965.JPG - un-retouched other than resize:
DNG - IMGP3965.DNG - default converted with Pentax DCU 4.21
Both shots should have EXIF data attached
(caveat: PhotoBucket can mysteriously drop metadata)
01-10-2011, 05:24 AM   #4
But the specific point is whether the adjustment controls in pentax photo lab 4 mimic the camera controls
01-10-2011, 07:26 AM   #5
i tried pentax dcu4 and i must say that im somewhat dissapointed, the incamera jpg are far better.
yesterday, i developed some raws and decided to compare against some jpgs. the first thing i noted was the pictures have more noise (chroma noise at iso1600) and some highlights looks wierd. everything with default settings, no corrections.
but, i will still use since i prefered the pentax color
01-10-2011, 02:03 PM   #6
Ah, ok... you do have the advantage of at least recall of what the original inquiry was
- whereas we can only (mis)interpret your single post re: mimic.
However getting to your clarified point
the adjustment panels available in Pentax DCU v 4.21 (the latest for the K-x)
these seem to give most of the camera settings including lens aberration adjustment/correction.
camera, dslr, photography, settings
New K10! - need suggestions for image settings Spock Pentax DSLR Discussion 17 01-05-2011 11:53 AM
K-x custom image settings SMeK Pentax DSLR Discussion 2 12-05-2010 03:24 PM
Kx custom image settings adwb Pentax DSLR Discussion 5 10-05-2010 07:45 AM
K7 custom image settings reset BGH Pentax DSLR Discussion 6 07-16-2010 05:46 PM
Just so we're clear, camera image settings Gooshin Pentax DSLR Discussion 6 06-25-2008 12:40 PM
All times are GMT -7. The time now is 06:54 AM. | See also: NikonForums.com, part of our network of photo forums!
