Originally posted by John Araki If you don't mind the goofy looks, you can set it up wireless using your on-board flash as the master and just hold the 360 off to the side. Works for me.
That's right - this too can be done. Only, the inconvenience of it requiring the flash's sensor to be within about 90 degrees of the control flash (a fixed popup flash), means that you need to be cognisant about which way the hand is holding the flash up to the control. With a hotshoe extension cord, there is no need to worry about this.
