Another tip for keeping your lenses/camera sensor clean.
When going from a cold area to a hot area, lenses may condense moisture. This may leave condensation on the lenses/sensor.
For instance if you have an opportunity to go through a cave and take pictures, you might find when you leave, moisture will collect on your lenses and glasses. If left their it can collect dust and lead small dirty spots on the glass outside and inside the lens..
Moisture spots that develop inside the lenses are very difficult to clean, and should only be cleaned by someone who specializes in cleaning the inside of lenses, preferably the factory who made it.
To help combat this, I recommend keeping several Ziploc bags in your camera case. Put your lenses and anything electronic in Ziploc bags, before going from cold areas to warm areas . This will prevent moisture from condensing on the glass or sensor. Also when going into a cave only remove what you're going to use, leave the rest in the plastic bags. Before you leave the cave put your camera in a large plastic bag preferably with some silicon gel packs. As a rule Caves are very humid.
Also, When I'm out taking pictures, I use a hurricane blower.
When I am at home I like a little bit more control and volume, so I can really get into the nooks and crannies. I took and bought a garden sprayer ( do not use one that has ever been used, it must be clean and dry inside ) and a cheap airbrush paint gun. I remove the standards spray wand and connected the air brushed hose to it.
Now with just a few pumps, I have a steady stream of clean air for several seconds. This allows me to be more precise of where I'm going to blow, and in what direction.
I also recommend a good air filtration system in the room where you work.
PS " Never used canned air inside your camera, " this could damage your mirror or sensor.
And I cannot recommend using a Q-tip to clean a sensor, they are not lent free. You may get the speck of dust or hair off the sensor but you may leave a piece of the Q-tip behind.
Only use swabs that are designed for camera sensors. If you can find one specifically made for that camera sensor use it.
joe1955
