Originally posted by wizardsnoop I'd like to see Pentax do something daring, I think a range finder type camera would be great, but what I really want is a FF square sensor.
You simply can not have FF and square
I do make some square images so I would want one, if that is availeble and not extreem expencive.
Do I see it possible?:
- one way is to fit it in a dslr with our current K-mount FF lenses. How big can the sensor be then? Maybe even 30x30 mm size, fitting in the middle and using the maximum space. So you could make it as the K-5 with a CMos and the same pixelnumber as the 645D (6315x6315=39,8 megapixel). Just not to many lenses in production at the time.
- the second way is to make a square sensor in the 645D with a size of maybe 43x43mm (again using the maximum space). Give it the same sensorbuilt CCD and you have a 51 megapixel camera. When you make it into a CMos like K-5 you even get 81 megapixels.
So there is plenty of oppertunity, but Pentax isn't big enough as a company to have a sensor designed just for them. The numbers of camera to be sold isn't big enough.
