01-17-2011, 08:38 AM   #1
MrHowell's Avatar
K-7 wont update
Got a question for anyone who can help or has had this problem was trying to update my K-7 to the new 1.11 firmware but it wont work doing either way the readme notes say to do. Thinking that maybe the firmware was bad I dled it again and same problem also tried dling the 1.10 update thinking that was the problem as I was only on 1.03 but that didnt work either. I have tried loading it from 2 different computers
and the same thing occurs when I turn on the camera holding down the menu button as instructed it shows me the current firmware but than goes into normal mode does not try to load the new firmware. Any and all suggestions would be appreciated.
01-17-2011, 08:53 AM   #2
RBellavance's Avatar
My guess is that you did not put the FWDC204B.BIN file directly in the "top-level" directory of the SD card. It should be at the same level as "DCIM", directly under the "drive letter" the SD card shows up as in Windows.
01-17-2011, 09:00 AM   #3
I have had similar problems, solution:
format the SD card with your camera and copy the firmware file to the sd card. now do the update as usual and all will be fine.
01-17-2011, 02:06 PM   #4
MrHowell's Avatar
Thanks to both of you for the response. Bellavance you had it right I was putting the update into the DCIM folder instead of just into the card so it was not seeing it when I turned on the camera my baby is now updated and as soon as Im done shoveling snow I can go back to shooting the birds at my feeders. Thanks again!
camera, dslr, firmware, k-7, photography
K7 wont take pictures in dark?? XeroX Pentax DSLR Discussion 14 08-03-2010 04:41 PM
PZ-70 mirror wont flick up Andi Lo Pentax Film SLR Discussion 0 09-11-2009 02:11 PM
Some of you wont like these.....Araneus!! Rense Post Your Photos! 11 08-10-2009 11:04 AM
Update on Remote Assistant Update fillerupmac Digital Processing, Software, and Printing 0 08-17-2008 01:43 PM
Need help..AF540 wont turn on. sychen Flashes, Lighting, and Studio 0 02-13-2008 06:20 AM
All times are GMT -7. The time now is 11:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
