10-06-2007, 09:00 PM   #1
indication of number of images taken on a k100d?
In most cameras, the external LCD will display number of available images left, which the k100d does, but then in playback, they'll tell you, for example, "Image x of y" or "1/450" or some such indication that tells you A. where you are in looking through the images and B. how many you've taken on your current card.
Where does this functionality exist in the k100d, and if it doesn't, who do I yell at to get it put in a firmware update?
Thanks,
Alex
10-06-2007, 10:52 PM   #2
SpecialK's Avatar
In the 9-image review mode, there is a slider on the right side that gives a rough approximation of where you are in the images. That's about as close as you'll get.
You have to do the math to know how many you've taken (number available when you format your card minus how many you have left).
I would contact Pentax regarding firmware suggestions.
Pentax Imaging - Home
10-07-2007, 08:27 AM   #3
You can yell at me
But it won't help with the firmware unfortunately
cheers
camera, dslr, images, indication, k100d, photography
Post Number 1000: Best Images To Date rparmar Post Your Photos! 14 07-26-2008 02:19 AM
number of recordable images jani Pentax DSLR Discussion 4 06-01-2008 01:22 AM
K10D Viewfinder indication adjustment ? ukbluetooth Pentax DSLR Discussion 5 02-29-2008 03:01 PM
K10D+BG2 Low Battery Indication? MNCurt-K10D Pentax DSLR Discussion 4 10-19-2007 08:35 PM
K100 has premature 'Low Battery Indication/ shut down" seriousam Pentax DSLR Discussion 19 07-09-2007 08:36 AM
All times are GMT -7. The time now is 09:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
