01-18-2011, 12:27 AM   #1
Broken Anti-Shake results in Focus issues
Way back in late September 2009, I sent my K7 in to the auth. Australian distributor for a possible anti shake failure. They returned it and said no fault found. (I trusted them but when i half pressed the shutter and turned the camera upside down i could hear a clunk). Some of my lens's weren't as sharp as my k20d but overall i though my body was out of alignment.
To combat the sharpness issue, I bought a LensAlign PRO and the photos were definitely sharper, but as the sharpness reduced i would test the settings i had and found that they were different every 6 months.
This month im off to south africa, So I decided I would take the lens's for a professional alignment (not a pentax repairer, but are a repair for nikon, canon lecia). I just got the quote back and they are replacing the anti-shake unit as they believe that that is part of the issue they are also shimming the lens, testing edge to edge focus etc.
Anyone else had a anti shake unit failure?
-Manny
01-18-2011, 07:18 AM   #2
Yes my K20d had a anti shake failure and Pentax replaced the guts of the camera under warranty.
Basically if anti shake was on, and the speed was slow enough (anywhere below 1/500th) The image would be ruined from anti shake adding blur
At higher speeds it was not a problem as 1/2000th etc was enough to totally freeze the 'action' of the faulty shake unit. Turning SR off fixed the problem.
01-18-2011, 07:33 AM   #3
jeffshaddix's Avatar
Wow that's quite a story. Glad you found out when you did. Did you have any other indicators that your SR went out?
Sometimes I notice a scratchy sound with SR on, but I imagine it was just a speck of dust on the platter, and it doesn't seem to affect the sharpness (yet).
alignment, anti-shake, camera, dslr, edge, failure, focus, issue, photography, sharpness, unit
anti shake on or off w/monopod Lance C Photographic Technique 4 09-26-2010 08:52 AM
Anti-Shake/Tripod? CPB.IV Troubleshooting and Beginner Help 3 07-24-2009 10:28 AM
EV compensation and anti-shake kcc Pentax DSLR Discussion 0 03-22-2009 12:12 AM
Questions about K10D and Anti-Shake smile-123 Pentax DSLR Discussion 0 02-10-2008 04:10 PM
Any problems with broken K10D anti-shake switch? Katsura Pentax DSLR Discussion 11 07-11-2007 05:48 PM
All times are GMT -7. The time now is 12:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
