01-19-2011, 09:14 PM   #1
Recommend a 2nd Hand 1st DSLR?
I shoot with an old KX SLR, don't have the set up at home for a dark room, (no window-less rooms,) nor the financial support for all those chemicals. So my reels go to the drugstore for developing and then I do my own processing in PS.
This is the kinda stuff I'm getting on film now. (Been shooting for about 2 and a half years now.)
I'm looking to get a DSLR, simply for the convenience of not relying on an outside facility to develop. At the end of the day it's cheaper too, with film going for $7 a reel at the least, aside from buying it in bulk online. I feel I'll have more freedom to experiment too. It's quicker, I don't have to worry about running outta reels or missing opportunities while re-loading. Plus I can shoot, edit and post within a shorter period.
I'm looking to get something second hand on ebay for a couple of hundred dollars, so my question is, what are some of the good ones? Pentax DSLR's that I'm still going to get a good use out off, regardless of many of them being outdated against the new K-5 and such?
I'm only after the body as I'm set for lenses. (At least... for now. )
I'm more interested in the sensor than the megapixel of course. I just want something to get my feet wet.
Any recommendations or tips would be awesome!
01-19-2011, 10:09 PM   #2
The K10D or K-x are solid second-hand options - I'd recommend one of those if you're looking for cost-effectiveness.
Here you can compare those bodies against each other and against the new K-5: Pentax Cameras | Pentax K-5 vs. Pentax K10D vs. Pentax K-x - Pentax DSLR Comparison - PentaxForums.com
01-19-2011, 10:15 PM   #3
lavascript's Avatar
Lovely shots you have there. I second the K10D. If you're used to shooting in manual, you'll probably prefer the dual-controls of the K10D over the single of the K-x.
01-19-2011, 10:16 PM   #4
bkpix's Avatar
I'll second Adam's recommendation, though I might stretch the budget and go for a K20D. In any case be sure to set aside a bit of money for SD cards, and, eventually, for a new hard drive or two.
01-19-2011, 10:22 PM   #5
While I would second Adam's recommendations, you need to start with how much you want to spend. Check the online used sources such as Adorama, KEH, eBay, or the marketplace at this site. In the USA, sometimes great deals can be found via classified ads in Craiglist or large city newspapers.
Good Luck,
Jim
01-19-2011, 10:38 PM   #6
lavascript's Avatar
Another thing to keep in mind is a wide-angle lens. With the crop factor, your 28mm "becomes" a 42mm. If you pick up a used body bundled with a kit lens, that'll get you to 18mm (27 eq.)
01-19-2011, 11:30 PM   #7
Ash
Ash's Avatar
Excellent work above.
All depends on your intended budget.
If megapixels aren't the issue, then I'd even suggest a K100D Super, which offers that beautiful 6Mp Sony CCD sensor - vibrant colours and excellent fidelity.
K-x would be the next suggestion, if funds suffice, but otherwise a K10D is an excellent choice - still a CCD sensor but a robust build and professional features and useability.
01-20-2011, 01:10 AM   #8
Had a quick browse on ebay, why are the K10D's going for more than the KX's?
This has caught my eye...
NEW PENTAX K-x DSLR CAMERA 18-55mm KIT WHITE~KX 18-55m (eBay item 290524246627 end time 21-Jan-11 10:26:44 AEDST) : Photography
At this point, I just wanna upgrade, lol, I'm tired of just imagining it in the distant future.
01-20-2011, 02:04 AM   #9
QuoteOriginally posted by Lindethiel Quote
I don't know why the prices on the K10d vs K-x, they are two completely different cameras. I would recommend however that Any Used dSLR you buy, make sure it comes with the cables and software. In some cases, you need the original disks to get the upgrades from Pentax (not to download them but to install them). Since used is an option you're willing to entertain, have a quick browse here in the marketplace.
01-20-2011, 04:45 AM   #10
Ash
Ash's Avatar
The K10D - older generation, but weather-sealed and robust build with pro-features at your fingertips.
The K-x - nifty, small, capable, great sensor, not weather-sealed, not as robust as K10D, lots of features, more fiddling with buttons and menus (if that matters).
Both good in their place - but the K-x is a great beginner's camera.
01-20-2011, 07:23 AM   #11
K200D - same sensor as the K10 (good IQ), Weather sealed, takes AA batteries like the K-X, beginners camera like the K-X, has some pro features like the K10 (battery grip, cable shutter release), costs less than K10.
01-20-2011, 08:11 AM   #12
For used cameras, reliable sources from all indications I've seen are keh.com and adorama.com
01-20-2011, 08:19 AM   #13
I'll second the quality of your film photographs. The suggestions above are all good. I might add that K20D's are coming down rapidly in price and are really nice cameras. I particularly like the ability to adjust the focus for each lens that I use on mine. I'll get a K5 before too long, but I still like my K20D.
01-20-2011, 08:20 AM   #14
Lovely shots! I'm guessing that, as you mention it being a family heirloom, you'll keep the KX? Please do as you've certainly got a way with it!
I'd agree that, on a budget, a K10 or K20 will be better for you as you'll have direct access to the settings in a way closer to the film slr you have. Both are still excellent cameras.
01-20-2011, 08:56 AM   #15
well if you want really cheap, KEH or Adorama have a few ist-DS for under $200.
certainly the K10/K20 are better cameras (e.g. weather-sealed and they have shake reduction) but if you really just want to spend $200 and you will be using your old Pentax-M lenses, then an ist-DS is plenty.
I must admit that there's something almost visceral about taking out my P3N... very simple. In a way that's what you'd get with one of the older cameras.
camera, dslr, film, hand, photography
35/50mm fixed AF lens-what price 2nd hand dinneenp Pentax SLR Lens Discussion 7 03-19-2010 08:58 PM
Around 2nd Hand Canon 1Ds Mk1 or Mk2 Worth The Money? Christopher M.W.T Canon, Nikon, Sony, and Other Camera Brands 3 03-11-2010 07:47 AM
Don't Underestimate Some Dodgy 2nd Hand Cheapie Lenses ;) Christopher M.W.T Pentax SLR Lens Discussion 13 01-04-2010 11:53 PM
How reliable is the P645N, been thinking to buy a 2nd hand or a new old stock nevin Pentax Medium Format 7 09-16-2009 01:43 PM
Which 2nd hand lens? Darius4522 Pentax SLR Lens Discussion 8 03-22-2007 01:34 PM
All times are GMT -7. The time now is 02:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
