Originally posted by indy
Yes there is a solution – turn your standby off.
I experienced the same frustrations and have found a solution that works for me.
In User mode go into your menu then tools screen 3 and select Auto Power Off and adjust to 30 minutes or off. When done, be sure to go to USER in screen 4 of the Camera Icon tab and save this setting. Now it will remember that you told it you are using a 55mm lens or other temporary adjustments like turning on bracketing or adjusting iso etc… These changes will now “stick” for 30mins or until you physically turn the camera off (if you have selected the “Off” setting) via the power switch.
Initially I was concerned with battery life, but have found it a non issue. I keep mine set to turn off at 30mins. When this happens the top LCD goes blank and any user changes I have made in that session are lost. When shooting I typically activate the shutter at least once every 30 mins. so I rarely if ever lose any temporary changes I have made in my user mode.
I love the user mode and wish the K7 had several like the K5. I can customize many settings that I like but do not want to be universal to the other modes in the camera. I use user mode almost exclusively with occasional forays into M when I need more control.
Thanks, I'd thought of that but worried about the battery draining too fast, I'm glad to hear it isn't such a worry. I too love the "User" mode, and also wish there were, say, four of them on the K-7. I think I'm skipping the K-5, but I might invest in the next Pentax generation (esp. if they give us full frame--lens wise I'm ready for that possibility) which will surely have at least as many User modes as the K-5.
