Originally posted by tim60 My only DSLR is K100DS. The most frustrating issue I have had with it is that the mount is the CRIPPLED KAF2 mount, which only allows use of manual K-mount lenses in wide open aperture. A local camera shop sales person (who also does camera repairs) seemed unaware of this variant of the mount. I have noticed noise in images which is intrusive at ISO1600 and 3200, but I would use 1600 if I can accept the grainy aesthetic. I find 3200 to be virtually useless. Overall I have been quite happy with the K100DS since I got it in late 2008, but I feel I would like to move up the market sometime to one of the newer models. But that means waiting for the money.
Try this to enable the use of k-mount lenses.
1. Setup SR function
Unlike newer lenses, the M lenses doesn’t provide focus length and aperture info needed for the SR function to work, so you have to manually input them. When I mount the lens to my K100D and turn my camera on (make sure Shake Reduction is on first), it automatically ask you to input the focus length info. You can change the value at any time by entering the “Rec. Mode” menu via the “MENU” button, and change the “Shake Reduction” value.
2. Allow the use of aperture ring
Go to the “Custom Setting” menu via “MENU” button, change the “Using aperture ring” value to “2 Permitted”. This setting will allow you to set aperture by using the aperture ring on the lens.
3. Change the AE-L button function
Go to the “Custom Setting” menu via “MENU” button, change the “AE-L bttn on M expsr” value to “2 Tv Shift”. This setting will let the camera to shift shutter speed when the “AE-L” button is pressed on manual mode.
4. Switch to Manual Mode
To put the camera into Manual Mode, turn the dial to point to “M”. Manual Mode will let you set the aperture value via the aperture ring on the lens. You can shoot in “Av” mode, but it will only work with the aperture open wide.
5. Switch to manual focus
Actually, you can shoot in “AF” but only if the focus is confirmed. Switching to “MF” will let you shoot anytime.
6. Select the correct ISO
On Manual Mode, Auto-ISO doesn’t work, so you need to setup the ISO value manually.
Good luck!
