01-29-2011, 04:31 PM   #1
Ed n Georgia's Avatar
K7 pre-flash (P-TTL)
Does anyone know how to disable the pre-flash from the pop up flash when shooting in full manual mode???
I suspect that it probably can't be done, but I'm not sure.
01-29-2011, 07:22 PM   #2
Lowell Goudge's Avatar
Never tried but I'd bet taking the lens out of A would work if the lens has an aperture
01-29-2011, 07:38 PM   #3
Thanks, I'll try that and let you know.
The Lens that I use most in the studio have aperture rings.
01-29-2011, 07:55 PM   #4
wlachan's Avatar
Disable red-eye?
01-29-2011, 09:38 PM   #5
QuoteOriginally posted by wlachan Quote
Disable red-eye?
Red-eye just adds some bursts prior to the metering pre-flash.
The only solutions are:
- Using the lens out of its A position (as Lowell said), but it will fire at full power.
- using a manual flash in the hotshoe (so you'll be able to dial the power down).
01-29-2011, 10:00 PM   #6
QuoteOriginally posted by dlacouture Quote
It's the metering pre-flash that I want to disable. I use radio triggers to fire my monolights. If I disable the metering pre-flash, I can fire them optically with the pop up.
It's not that I want to do this all of the time. I had a radio trigger failure and have to use a PC cord. I just think it would be a lot easier if I could use the pop up. but, with the metering pre-flash, the monolights have already fired before the shutter opens.
I'll try shooting out of the "A" position and see what happens.
01-30-2011, 02:15 AM   #7
The problem is that with the built-in firing at full power, it may register in your photo...
That's why an inexpensive manual flash could be a good idea. Or maybe a Nikon SG-3IR flash screen, if you want to keep equipment to a minimum (and it is useful when you want to use P-TTL wireless in controller mode, as the K7/K5 has a pretty strong minimal power)...
01-31-2011, 07:50 PM   #8
More....
The metering pre-flash is eliminated when shooting out of "A". The K7 indicates that the flash output can be reduced by a factor of -2.0 when the body is in manual mode. I didn't have the proper equipment with me to do and accurate measurement to see if it actually does lower the output..
I did put my hand a few inches in front of the pop up to block the flash from hitting the scene directly. My monolights did fire optically with my blocking.
Of course, this is nothing I intend to do on a regular basis but use as a method if I have a radio trigger failure again.
More later once I accurately measure the pop up flash intensity.
02-01-2011, 12:00 AM   #9
QuoteOriginally posted by Ed n Georgia Quote
It doesn't. The flash power reduction setting has no effect when the lens's aperture ring is out of the A setting.
I tested with a K7, a Tamron 90mm macro (aperture ring at F/2.8), and a Minolta Auto Meter IV F.
02-01-2011, 08:04 AM   #10
QuoteOriginally posted by SOldBear Quote
Thanks, Good info.
I was going to run a similar test, and may still do it, with my FA 77 and Sekonic L358.
camera, dslr, photography, pre-flash
Difference between TTL and P-TTL flash. rod_grant Pentax DSLR Discussion 35 12-25-2012 06:42 AM
Pre-flash to flash time lag? Raven Flashes, Lighting, and Studio 3 07-24-2008 06:57 AM
K10D Pre-flash anomaly Pentax DSLR Discussion 3 03-09-2008 07:14 PM
P-TTL pre-flash question - is it visible? BobG Flashes, Lighting, and Studio 7 02-18-2007 04:38 PM
All times are GMT -7. The time now is 08:20 PM. | See also: NikonForums.com, part of our network of photo forums!
