Edit: There is now a dedicated Android App for controlling your Pentax camera using this method. Get it here:
LINK (New version 1.1 with vastly improved range)
It is not on the Market Place because it was developed using Android AppInventor which does not (currently) allow you to upload apps to the marketplace.
This BETA! Please report bugs :-)
Thismorning I stumbled upon this
Instructable detailing how to make an IR transmitter using an audio jack lead, which would then transmit any IR code using a custom .wav file. This is one of those situations where in a cartoon a lightbulb would have appeared above my head - idea!
So this is a very quick guide as to how to utilize the IR lead in the above instructable (and kudos to alberto_canvas for a very informative guide as to how to make the lead) in order to use any MP3 player/phone or laptop (although I would highly recommend
PK_Tether in that instance), basically ANYTHING that can play an audio file, as an
intervalometer or remote timer.
Here are some shots from my build.
I started with a headphone extension lead, from Poundland (luckily I thought the one Maplin sold for £7.99 was a ripoff) and the two IR LEDs are from Maplin, code YH70M, just over a quid each.
Testing. Believe me, when the shutter went off this was a real EUREKA! moment for me. You have to wire them up so that the positive leg from one LED is attached to the negative leg of the other LED. This is NOT a parallel circuit - they are two opposing diodes. This becomes clear later. Also, my lead has a red, white and yellow wire. The yellow is ground, and is not connected to anything.
I decided to file down one edge of each LED so that they fitted next to each other nicely (you have to make sure to file the correct side on each one else the leads don't go well together)
See I started filing the wrong side on one of them.
I used thin shrink tubing on one lead and then larger shrink tubing to cover both the leads, then wrapped the whole lot in insulation tape.
Finished. Very simple. I guess it took about 2 hours to make but that included the time it took me to figure out how to make the .wav file work.
So that's the lead. The next step is the .wav file. I found the correct code from
this thread. It looks like this.
So here's the important bit. To be honest i'm not sure that what I'm about to say is technically correct but, well it works so there you go. The IR code signal is 38kHz but the .wav file we will create cannot go that high. So what we do is use pulses of 19kHz, and because we have two LEDs wired opposing each other, one LED will 'light' up during the positive part of the wave and the other will light up during the negative part of the wave, so that for each wavelength we actually have two pulses - so a 19kHz wave gives us 38kHz pulses. Follow me? To make sure this works, only one channel (I've made it the left channel) can transmit the signal because if both channels do then they cancel each other out. Or you could invert the signal on the right channel (possibly leading to a stronger IR pulse - need to experiment with that).
The signals are created simply using the "Generate, Tone" function in Audacity. I specified a square signal and 19000 Hz, for 13 milliseconds for the first long pulse and then 1 millisecond for the subsequent pulses.
Here's a screenshot of the .wav file I created, I used Audacity which is free.
LINK
Once it is saved as a .wav, use windows media player or something to check it works. In case you hadn't guessed, the lead you made just plugs into the headphone jack of your computer/MP3 player/whatever. It's funny though - this didn't work with VLC. But windows media player did work. Meh. It also worked when I converted the file into an MP3, but possibly less reliably? Not sure. I would stick with wavs unless your device can't play them.
To make this into a useful timer, you need to create a track with the signal at the beginning, followed by X amount of silence, and then simply play the track on repeat. However I have found it hard to gauge how much time to leave - for example when you set the shutter speed to 30 seconds the time between shots is actually a bit longer than this. For this reason I prefer to use bulb mode, so the .wav is laid out like this:
SIGNAL - 30s silence - SIGNAL - 2 seconds silence
with this on repeat, the camera will continuously take 30s shots until the memory card is full/batteries run out. Whatever, experiment, see what you like. Watch out for DFS though, but then you could even account for that by putting in the appropriate amount of silence for DFS.
Anyway the point is this is a really really simple way to make your k-x into a time-lapse or astrophotography beast! You could even set up a playlist to give you, say, 100 exposures at 30 seconds, 10 exposures at 5 seconds, or whatever. I'll be making some sort of mount to attach the lead to the camera close to the IR port, possibly even just an elastic band or something.
Finally here's a zip of the audacity project and the raw .wav file (Now with improved range by putting the inverted signal on the opposite channel)
Hope you enjoy.
EDIT:
This is why the mp3 does not work quite so well:
I didn't imagine the mp3 would be quite so screwed up! I would definitely recommend some sort of lossless compression, for example ogg vorbis which looks a LOT better:
Also, as lavascript points out, this is useful for any pentax camera not just the k-x. However it is particularly useful for the k-x as it has no timelapse functionality.
Edit #2:
Android app is in progress. It is functional as a basic intervalometer at the moment, needs a bit of spit and polish but I should be able to 'release' it soon.
