10-11-2007, 09:08 AM   #1
K10D in the rain ?
Made a trip to the Oregon Coast yesterday. Heavy rain & some wind. Took pics. w/the K10D & 'Kit' Lens's. The 18-55mm lens/camera became erratic. It would 'fire' periodically however at times I would have to wait as long as 1/2 min. With the 50-200 mm lens I had no problem. My assumption is that there was no problem w/the camera as long as I had the 50-200 attached so probability is that moisture/water caused a problem while using the 18-55mm. This range of lens is important to me so should I be looking @ an upgrade? What are the reasonably priced options for replacement? Thanks for the help. I purchased this set up in July of this year.
10-11-2007, 09:20 AM   #2
pschlute's Avatar
Did you try cleaning/drying the contacts ?
10-11-2007, 09:36 AM   #3
Miserere's Avatar
Remember that although the K10D is rainproof, the DA lenses are not. If you want weatherproofing then you'll have to dish out around $1000 for a DA* lens.
On the cheaper side, plastic bags and rubber bands can go a long way...
18-55mm, camera, dslr, k10d, lens, photography, rain, w/the
k10d with non weatherproof lenses in rain? daverowe Pentax DSLR Discussion 21 01-04-2010 02:09 PM
Haka, rugby and rain and RAIN Arpe Post Your Photos! 15 05-14-2009 06:09 PM
K10D in HEAVY rain - works as intended NaClH2O Photographic Technique 16 06-24-2008 01:27 PM
K10D + Bigma + Drift...+ RAIN! blwnhr Post Your Photos! 15 11-05-2007 03:44 PM
K10D all wet from rain imadethis Pentax DSLR Discussion 11 09-23-2007 06:33 PM
All times are GMT -7. The time now is 04:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
