02-13-2011, 05:21 PM   #31
pete_pf's Avatar
QuoteOriginally posted by eddie1960 Quote
that is odd, as when i look at the preview on importing it's fine but once i have it in lightroom it's the same issue. So it's not your software, it could still be a corrupted hard drive partition
try a clean import of a file and work from the memory card and see if it is a problem
can't already formatted the card lol boo. can you redownload that file? i added the pef file i took from my laptop, and it seems to be loading ok (for now lol)
wondering if anyone can find why the one pef loads fine and the other doesn't? i know the names are different, but even when i rename the file back to the original on my desktop it goes corrupt. this one in the zip is renamed just like i did on my desktop. also want to remind people that i got the corruption on my laptop as well, so don't say it's my desktop :P
02-13-2011, 07:37 PM   #32
eddie1960's Avatar
Ill tty agsin when im back online
May not be till tomorrow though
02-13-2011, 08:31 PM   #33
pete_pf's Avatar
i know this will bite me in the ass for posting. ok, so i went on my laptop to see the image to see if it loads there (i originally saved it there from my card). it did, so i saved it in my dropbox and then checked it on my computer (where i'm currently having the issues) i load up the image, everything seems ok. i bring in my xmp file, all my editing is there, no issues so far. i read the other comment about renaming and exif issues, so i didn't rename it like i usually do this time. but so far the image loads and edits fine, so now i'm even more stumped about this lol
my original process from my memory card was 'add metadata > rename-move to laptop > move to external hard drive' - why all the moving? originally put on my laptop to view and edit a little, then realized editing on laptop sucks, so moved to desktop. i'm wondering, possible there's some read/write issue when i move from laptop to external hard drive? my external was formatted under xp, maybe 7 isn't reading them probably when i move them over? next time i'll move straight from camera to external to test that theory out.
02-13-2011, 10:17 PM   #34
sterretje's Avatar
QuoteOriginally posted by twitch Quote
I'm not sure if this has been mentioned but I tihnk it's an important point.
What is seen on the camera LCD, and on the computer screen during and soon after import is not the RAW file at all (or even the computer converted RAW file), it is the JPEG embedded within the RAW file. Once the computer processes the RAW file it then generates it's own JPEG preview which it uses to display the photo on the screen rather than the JPEG embedded in the RAW file. This can take from seconds to many minutes depending on how many images were imported and how fast the computer is.
You can never see a RAW file displayed, only the JPEG/TIFF interpretation of it.
If the file "goes crazy" it could be that the conversion of the RAW file to JPEG on the computer has screwed up, so as it replaces the embedded JPEG for it's preview with the RAW converted one it's at that point that it may be screwing up.
It is my understanding that when pete_pf starts editing the image is OK. So that should not be the embedded jpeg but the converted raw.
02-13-2011, 10:21 PM   #35
pete_pf's Avatar
QuoteOriginally posted by sterretje Quote
yes. the raw file is usually ok for about a day lol i did literally nothing to the image but basic raw editing, i click save, then ctrl+r at a later time, and it goes funky.
has anyone had their images goes nuts like this, or am i the only one? lol please let there be others except me :P
02-13-2011, 10:25 PM   #36
sterretje's Avatar
So to get the overview, this is your process
Download files from camera to laptop
Edit on laptop
Move to external harddisk (make this a copy in future till you're sure the copied image is OK)
Connect external HD to desktop
Edit on external HD and the problem shows at occasion
Is this a correct summary?
02-13-2011, 10:33 PM   #37
pete_pf's Avatar
Edit on laptop
yuuup from laptop to external it's always copy because from folder to folder windows copies by default, but from camera to where ever i usually move by renaming straight from sd card inside bridge. "problem shows at occasion" exactly why this is so annoying. if it happened to every image every time, i could understand. but that it happens so randomly ... aggh.
02-14-2011, 03:46 AM   #38
jolepp's Avatar
My guess currently would be that you are seeing the effects of a marginal data block somewhere in the chain of medias (of which the memory card is least suspect as it has passed the polygraf alredy ). Actually, the problematic block might even fail quite consistently but then the effect of that could vary depending on what exact location a image file it ends up.
If you have the space you might let the copies that are created at various stages to to stick around. Then, when/if this happens next time you could go back in the chain of copies to locate the first copy without / with the problem and then take it from there: e.g. if the copy on the laptop is good, but the one on the external HD is not, then the HD would seem to be the one to blame.
I suppose H2testw could be applied to the other disks in the copy chain as well; it simply writes out a file with generated data on the disk in a location you can give, reads the file back and checks it gets the expected data back (and finally gets rid of the test file). The check part failing should mean having identified the culprit. Another thing you might do (for all the memory cards and hard disks involved would be "MyComputer - <disk X> - Properties - Tools - Check for errors" with the option "scan for bad sectors" checked in addition to "automatically fix ..." (takes a fair bit of time, as it goes through the entire disk). In case Windows finds "bad sectors" its marking them as such should mean that you image files do not end up using these (it is worth noting that the list of bad sectors is cleared with format).
02-14-2011, 03:57 AM   #39
borno's Avatar
I wouldn't rename the raws if that is what you are doing. Put them in a folder with a name of your choosing and rename after converting to .jpg . I would look at the simplest solution first.
02-14-2011, 10:22 PM   #40
I had this problem when I used an external SD card reader. It was a really cheap 5$ one, but it was blazing fast.
Try transferring from your camera instead of using an SD card reader. Or alternatively, try using another sd card reader.
My theory is that the cable you use for USB may not be well shielded enough, so corrupted data is flying by.
02-15-2011, 08:56 AM   #41
jolepp's Avatar
QuoteOriginally posted by 0rangepeel Quote
I had this problem when I used an external SD card reader...
Good point, a flaky reader / cable could cause occasional corruption like this. In general the really annoying part of this sort of thing would seem to be infrequent-but-still-sometimes-happens -ness. On a related note I wonder whether Windows still retries a failed i/o operation behind the scenes which tends to result in things getting flaky going unnoticed until the trouble gets so bad that a couple of retries do not help any more.
02-15-2011, 09:35 AM   #42
pete_pf's Avatar
ohh man wouldn't that be heaven is this was the problem? instead of memory or hard drive issues that it could be as simple as getting a new usb cable or reader?! i wonder if that's the issue though, because when i moved from camera to laptop the image is fine. but when i connected my laptop to my external hard drive, that is when the image went nuts. also when i moved the images from this post from desktop to laptop i used a card reader. i would just love is this was the problem with the most recent image that went nuts, i recently put the image into my dropbox and downloaded to my desktop, and it's working fine so far on there. so really has me thinking hmm
02-15-2011, 11:45 PM   #43
sterretje's Avatar
You have to do some trouble shooting (with sensible thinking) and draw the conclusions. You have a system now where files don't get corrupted and you're now working on images that are on the HD of your desktop (if I understand it correctly).
What is the difference between the current setup (dropbox) and the previous one (external HD)? That you don't use your external HD anymore.
So what can be wrong? External HD, cable, usb ports on both laptop and desktop.
The sensible sequence of tests will start at the source (laptop/external HD). I do have a suspicion as to what is going wrong so I will start at the other side. Where do you connect your external HD to the desktop? Front or back? Assuming this is an external HD that gets its power from the USB ports and you connect to the front, you can eliminate the front USB as a source by using the USB at the back.
1)
1a) Copy images from your laptop to the external HD.
1b) Connect external HD to one of the USB ports on the back of the desktop.
1c) Edit a couple of them on the external HD.
1d) Does the problem occur?
If not, the problem is the USB ports on the front of the desktop. And the (more than likely) reason is that those ports canít deliver enough power to the external HD because they are wired with thin wires and when too much power is required, the voltage will drop. And I think that that is currently your problem.
If yes, no conclusions can be drawn except that my suspicion was wrong and I would start at the source (laptop / external HD)
2)
2a) Copy images from your laptop to the external HD.
2b) Edit a couple of them on the external HD using the laptop.
2c) Does the problem occur?
If not, I would conclude that it's the combination desktop / external HD that causes the issue; go to step 3
If yes, test the external HD while connected to the laptop; maybe jolepp's tools that you've already used can do that (not sure). Also test laptop's memory and internal HD.
3)
Iím not sure how to continue. The dropbox solution proves that your desktop is basically OK (possibly except for USB). I would test the external HD while connected to the desktop using joleppís tools (on the front USB as well as on the back USB).
Good luck.
PS Donít ask me why this problem shows up in Win7 and not in WinXP. Only God knows
02-15-2011, 11:59 PM   #44
Sounds to me like it's the external drive.
02-16-2011, 02:32 PM   #45
I just caught up on this thread. twitch made a very good point mentioning that the RAW file contains an embedded JPG for preview purposes ... another complexity to consider while trying to find the source/fix for this frustrating corruption problem.
A question to everyone: wouldn't an intermittent problem with a memory card, cable, or hard drive likely cause additional problems? It seems like the photo corruption is always happening in a similar manner. I would expect a memory problem to sometimes corrupt files badly enough to prevent opening them.
pete_pf, the 3 sample images you provided all start with a good band at the top. Have you had any photos that were 100% garbled? That started out bad at the top but then were good at the bottom? That were so bad you got an error message trying to open them?
camera, dslr, files, photography
RAW duplicate images - saving as RAW files jpzk Digital Processing, Software, and Printing 17 02-15-2010 07:01 PM
DxO doesn't correct images/ Am I doing sth. wrong? Egg Salad Digital Processing, Software, and Printing 9 01-28-2010 05:35 PM
Damaged Files - How to recover sabarrett Digital Processing, Software, and Printing 9 10-30-2008 04:24 PM
yesterday's images... (warning - larger files x3) Marc Langille Post Your Photos! 24 11-14-2007 05:09 PM
New hummingbird images... (warning- some large files) Marc Langille Post Your Photos! 24 09-29-2007 09:57 AM
All times are GMT -7. The time now is 01:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
