02-03-2011, 07:44 AM   #1
Would you buy k200D or K-x as backup (for k-x owner)?
Which one will you buy as backup if you already own k-x ? K-x or K200D ?
Advantage of having same camera as backup is that usability is good. On the other hand, as I read k200d & k-x have different rendition and would be useful to have different model as backup.
What's your opinion?
Yusuf
02-03-2011, 07:58 AM   #2
I would go with the K200d - it is a nice build, has an inexpensive (if you can find one) grip option (which would help balancing some of your longer/heavier lenses), and is weather sealed - you could couple it with the cheaper WR lenses for an inclement weather camera.
02-03-2011, 08:06 AM   #3
I like the K200D. It has problems with high ISO, but my K-R works great for that. Yes the rendering is different, I like the CCD sensor in the K200D for daylight. BTW the battery grip is WR too.
02-03-2011, 09:03 AM   #4
catsman50's Avatar
QuoteOriginally posted by yusuf Quote
Yusuf
I was just in the same position as you I have a kx and wanted a "beater camera". So I ended up getting a k200 with a grip and its great!built like a brick and weather proof as well.
02-03-2011, 09:05 AM   #5
I would go with the K200,it just feels right in the hand
02-03-2011, 09:30 AM   #6
I would go with the K200D as it will be cheaper and has the weather sealing on it. Even though it's not bulletproof in terms of weather sealing but it will definitely be better than the Kx with no sealing at all.
02-03-2011, 09:41 AM   #7
Yusuf
If the K200d has different rendering (K10d sensor and weatherproofed as well, can also be fitted with a grip, but won't give you the ISO performance you enjoy with your K-x), then it wouldn't be a 'backup' but a second camera. Right? I'll never understand this having a Different machine as a Backup. I can understand having a second camera to Use if something craps out on your main camera though.... if that's what you mean by Backup.
02-03-2011, 10:48 AM   #8
QuoteOriginally posted by JeffJS Quote
ok, let me reword it then second cam...oops no..third cam..I already have two k-x
02-03-2011, 10:48 AM   #9
this is good advice, i would get the k10d/k20d/k200 or w/e camera that pentax made with the CCD sensor, that one give better low ISO performance, and use the K-X for high ISO performance... and grab something with WR so you can run about in wet weather.
02-03-2011, 01:44 PM   #10
So what you Really want is a collection of K-x's in different Colors. I'm just giving you a hard time.. No one here takes me seriously anyway .
I never had either camera so I'm only going by my experience with the K10d. One would assume you are considering the 200d for the AA battery compatibility and perhaps body size. If you are truly looking for a low ISO workhorse however, Do consider the K10d.
02-03-2011, 06:07 PM   #11
Yes the K200D shares batteries with the K-X and from what I've seen sells for less than the K10D. I've found it annoying to have to carry three different battery chargers while traveling.
02-03-2011, 06:55 PM   #12
Three?
02-03-2011, 08:52 PM   #13
btw, doesn't k10d and k200d offer the same low ISO IQ?
02-03-2011, 09:17 PM   #14
My caveat before answering that is that I've never used a K200d. From what I understand however, they have the same sensor.
02-04-2011, 07:01 AM   #15
Three?
Wifey MUST have her little Canon P&S!
backup, camera, dslr, k-x, k200d, k200d or k-x, photography
Owner of a K200D wondering if anyone has come across this before? k8star Pentax DSLR Discussion 1 07-03-2009 11:33 AM
new Pentax K200D owner BEENS Pentax SLR Lens Discussion 4 02-27-2009 03:07 PM
New K200D Owner jezza323 Welcomes and Introductions 5 01-15-2009 01:33 PM
K10D owner --> I'm confused, just tell me which lens to buy. Sunnyqueensland Pentax SLR Lens Discussion 21 04-16-2008 03:24 PM
DS owner, buy k10d or wait little bit longer ? feronovak Pentax DSLR Discussion 19 05-05-2007 06:38 AM
All times are GMT -7. The time now is 10:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
