02-05-2011, 07:51 AM   #1
Dual AF360s for Contrast control sync
I heard that if you have two AF360 flashes (One on the camera and one external) you could set them up to do Contrast Control Sync.
When I look at the AF360 manual it states that :
When the AF360FGZ is used in combination with the camera's build in flash you can do contrast control sync.
Does anyone know if it is possible with two AF360's without a wireless equiped camera?
02-05-2011, 09:18 AM   #2
Ole
Ole's Avatar
Contrast control sync requires a wired connection - so wireless is not required/not possible. It is correct, that the built-in flash can function as one of the two flashes in the set-up. You thus do not need two external flashes, just one.
af360, camera, contrast, control, dslr, photography, sync
Off camera use of AF360FGZ with K10D - 'contrast-control-sync' GlumGrum Flashes, Lighting, and Studio 4 08-02-2009 06:55 AM
High-speed sync control beest Pentax Camera and Field Accessories 1 07-23-2009 09:36 AM
Wireless Contrast Control Sync Flash? Taikonaut Flashes, Lighting, and Studio 2 04-29-2009 06:57 PM
Contrast Control Sync flash mode proudtoshootpentax Pentax DSLR Discussion 0 03-01-2008 10:55 AM
contrast control sync: 540FGZ + K10D built-in flash WMBP Flashes, Lighting, and Studio 6 09-23-2007 02:28 AM
All times are GMT -7. The time now is 02:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
