02-05-2011, 10:52 AM   #1
zman's Avatar
? need help upgrading K7 firmware ?
I'm having a problem upgrading to the newest version firmware for my K7.
I have successfully downloaded the firmware to my PC. Have opened it and extracted the two files, README and fwdc204b.bin.
I copied & pasted the firmware file from my PC onto a formatted SD card. The SD card shows it does contain the new firmware file in the root directory.
Having loaded the SD card into my K7 and holding down the menu button as I power up, the lcd reads V1.0 and then proceeds to the standard menu options. I never get the "NOW LOADING" or "PROGRAM UPDATE" prompts as per the Pentax instructions.
My battery is fully charged and I've attempted my upgrade using two different SD cards. I'm stumped. What am I doing wrong ? Any suggestions ?
02-05-2011, 11:45 AM   #2
zman's Avatar
Part 2 of my story ...
Hi Again,
I've been researching old threads regarding my problem and I think I've found my solution but don't know how to correct it.
I've been pasting the firmware bin. file to my card via "h" drive (my memory card reader) to DCIM, which I presumed was the root directory of my SD card. i.e - h/DCIM. My ? is, where is the root file exactly and how can I find it ?
Thanks.
02-05-2011, 11:52 AM   #3
Format the SD card, then copy the .bin file to it. It does not go in a DCIM folder! The root is always the lowest level of any file system.
Assuming your card will be the H: drive, you should see h:/ fwdc204b.bin.
02-05-2011, 12:06 PM   #4
zman's Avatar
Success !!
Thank you JohnX for your help. You were exactly right, I had been pasting the firmware file into the DCIM folder. I have now learned that it stands for " digital camera images" folder and that's where my images are stored onto the SD card. My firmware upgrade was completed just as my Pentax instructions said it would.
Whew !
02-05-2011, 12:08 PM   #5
You don't need to format the card. Just make sure you can see your BIN AND the DCIM directory when you look at it. If you are formatting the card in your camera it will always leave the DCIM directory. I've never once formatted the card before updating (perhaps some day to my own peril).
camera, card, dslr, firmware, k7, k7 firmware, menu, pc, photography, sd
Those getting a K-5 : What will you be upgrading from? adamfogerty Pentax DSLR Discussion 44 02-01-2011 02:42 PM
Upgrading my K-X danpinoy Pentax DSLR Discussion 16 09-15-2010 03:38 PM
Problem upgrading my K-x to firmware ver. 1.01 Tim_R Pentax DSLR Discussion 7 03-09-2010 05:26 AM
K20D - Worth upgrading firmware if I have no hot pixel issues? NicholasN Pentax DSLR Discussion 6 01-07-2009 01:24 PM
Upgrading My K10D Firmware. NLAlston Pentax DSLR Discussion 9 01-23-2007 08:54 AM
All times are GMT -7. The time now is 04:44 AM. | See also: NikonForums.com, part of our network of photo forums!
