02-07-2011, 07:51 AM   #1
starbase218's Avatar
Location: Planet Earth, Sol system, Milky Way galaxy, Universe
K-7 horizon misaligned?
Hi,
I have a K-7. Had it since march or april last year. I like it a lot, but there's one thing that bugs me. The electronic horizon seems to be off. When I take a photo of a centered spirit level (googled this word up, so I hope it's right), I have to rotate the body a notch or 2-3 to the right to have it appear exactly horizontal on the photo. When taking photos, I often notice the same effect. Is the electronic horizon indicator in my K-7 faulty?
02-07-2011, 08:47 AM   #2
KansasHorizons.com's Avatar
2 of my 2 k-7s were not correct....
02-07-2011, 08:51 AM   #3
Short answer, yes. That is, faulty in that they are all (or most of them) off. Apparently there is no easy way to calibrate it either so most just shut it off and trust the viewfinder. Or at least I did.
02-07-2011, 08:54 AM   #4
QuoteOriginally posted by KansasHorizons.com Quote
It is still under warranty, but from your reply I figure a repair or replacement probably won't help?
02-07-2011, 09:00 AM   #5
SpecialK's Avatar
Discussed here:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/87206-k-7-electronic-level.html
02-07-2011, 09:31 AM   #6
Thanks. Looks like I will be sending my K-7 back after all. If it can be fixed, I want it to.
02-08-2011, 01:45 PM   #7
QuoteOriginally posted by starbase218 Quote
It can be fixed, they (Debeukelaer in Antwerpen) fixed my new K-5 under warrenty.
It took them no more than 5 weeks for getting K-5 adjustment software from Japan however....
If the K-7 software tools are the same as the K-5, you should be fine.
- Bert
02-12-2011, 03:49 AM   #8
Well the camera's on its way. My lenses are already missing it .
02-12-2011, 02:17 PM   #9
You can call Debeukelaer and ask for the service department.
They will tell you the progress on their repairs.
Make sure to have your serial number and the name of the shop that is sending it in at hand.
- Bert
02-13-2011, 05:21 AM   #10
Does anyone know if this affects the automatic horizon leveling also, or is it just the "spirit level" display that's off?
02-16-2011, 11:57 AM   #11
QuoteOriginally posted by pentup Quote
Don't know for sure, but I would be surprised if it doesn't. That would mean having two sensors in the body, or two separate and different algorithms to retrieve the sensor data in the software, to do the same thing. Seems like a wasted effort either way.
02-16-2011, 11:59 AM   #12
QuoteOriginally posted by bymy141 Quote
- Bert
Thanks, I might do that.
02-16-2011, 01:16 PM   #13
Mine works fine.
camera, dslr, horizon, k-7, photo, photography
Landscape Sun on the Horizon LucyGoosey Photo Critique 11 08-26-2010 03:29 AM
DA* 300mm Aperature blades misaligned Roland303 Pentax SLR Lens Discussion 17 04-07-2010 02:43 PM
K-7 Horizon correction. LeDave Pentax DSLR Discussion 2 12-11-2009 11:41 PM
K20D Focus Indicator Lights Misaligned? lowbit Pentax DSLR Discussion 1 03-16-2009 10:18 PM
Misaligned/Leaning Images of People (Photo Fundamentals) stewart_photo Photographic Technique 30 10-17-2007 06:33 PM
All times are GMT -7. The time now is 12:33 PM. | See also: NikonForums.com, part of our network of photo forums!
