02-09-2011, 09:12 AM   #1
johnny9fingers's Avatar
SR on all the time?
Do most of you folks keep the shake reduction feature on all the time, or just when shooting at slower shutter speeds? Is there a loss in IQ when using it at speeds above 1/125?
Thanks
John
02-09-2011, 09:18 AM   #2
boriscleto's Avatar
I always shoot with SR turned on. Except for when the camera turns it off, timer etc, or when it should be turned off, tripod etc.
02-09-2011, 09:41 AM   #3
KFrog's Avatar
Almost always on
I have SR on all the time unless I put the camera on a tripod. It's great for even my old Takumar lenses.
02-09-2011, 09:56 AM   #4
dadipentak's Avatar
QuoteOriginally posted by boriscleto Quote
Me too.
02-09-2011, 10:10 AM   #5
RioRico's Avatar
No, SR doesn't reduce IQ at faster shutter speeds. I use SR at all times, except:
* As noted above, for tripod, timer, remote, etc.
* Handheld macro shots, where SR is ineffective.
* Old manual zooms, where I change focal length.
About the last: People have various calculations for setting SR for old manual zooms. What to tell the SR-bot for a Vivitar 70-210/3.5? I tell it nothing. I just find adequate light and SHOOT, like Back In The Day before we had stabilization.
Think of it this way: SR is most effective for certain focal ranges at slower shutter speeds. Falk Lumo has posted graphs showing the effectiveness ranges. Outside those ranges, SR doesn't hurt. SR *does* hurt if the camera is fixed, as on a tripod, or if the lens' focal length doesn't match what you've told the SR-bot. So if I mounted that 70-210 and told the 'bot that it was some fixed focal length, SR would diminish IQ the further I got from that FL. Thus I might tell SR that the lens was 200mm, then ONLY use it in the 190-210 range. If I zoom out to 70-100-135mm, it's time to switch SR off. Or else, re-enter the new FL, which gets to be a pain. Depends on how long I intend to stay at any specific FL, eh?
02-09-2011, 10:12 AM   #6
v5planet's Avatar
I wouldn't have thought this -- is there any downside in keeping it on for such shots regardless?
02-09-2011, 10:31 AM   #7
KxBlaze's Avatar
Same as others. Always on unless on a tripod.
02-09-2011, 11:58 AM   #8
trojancast's Avatar
Ditto, always on.
02-09-2011, 12:07 PM   #9
Ira
QuoteOriginally posted by v5planet Quote
My guess is that he's so close...and since SR doesn't help subject movement and even slight movement in macro is magnified 10 fold...that it would do no good anyway.
But I guess my guess isn't really a downside, like you asked about.
02-09-2011, 12:10 PM   #10
Ira
Always on, but for me, there's an additional reason:
For those of us who mostly use old manual glass, the FL isn't recorded in the EXIF data if SR is off. (And I ain't the organized type to archive my files by lens used.)
Stupid SR.
02-09-2011, 12:41 PM   #11
I don't know that there is any benefit to turning it off, but when you are focusing really close, the SR is not really able to compensate for your movements, which are magnified. The only things that will compensate will be increasing your shutter speed a lot or, using a tripod.
02-09-2011, 09:21 PM   #12
Thanks for all the reply's. SR was one of the features I like to have and use quite a bit, and now I know it's ok to use it anytime the camera is in my hands.
Thanks again...
02-09-2011, 10:41 PM   #13
v5planet's Avatar
Well I meant more so: would leaving it on be to the detriment of the photo in such a circumstance? Doesn't sound like it, but I asked because it's not something I think I would trust myself to remember to do (turning off the SR) when a hand held closeup opportunity presented itself.
02-10-2011, 01:14 AM   #14
Hypocorism's Avatar
QuoteOriginally posted by johnny9fingers Quote
I leave it on, totally forget about it, just concentrate on important things and don't bother turning it off when I put the camera on a tripod like it says in the manual because that's only the completely out of touch with reality thinking of maroons who author dumb manuals.
They probably run Loonix OS on their PCs and drive black Volvos too...
...and use iPhones with all the latest kewl gadgets installed hoping it will get them laid.
.R. -- Who expects manuals in AD 2011 to be comprehensible to real humans whose direct ancestors can walk upright.
02-10-2011, 01:54 AM   #15
Sorry to take you to task on this, RR!
In the case of a vintage zoom, when the actual FL doesn't match the FL you input to the camera, you don't diminish the IQ, you merely reduce the effectiveness of the SR.
This holds true for all cases of the actual FL being longer than the entered FL. You need to be careful the other way round though: if the entered FL is more than twice the actual FL, you will indeed diminish IQ - in fact, you'll end up magnifying any camera shake.
As you're probably aware, I did some calculations regarding the best compromise FL for a vintage zoom, but I hesitate to post the link for fear of boring everyone!
camera, dslr, photography, speeds
help! pentax K-M requires adjust date time all time carl zeiss Pentax DSLR Discussion 9 10-05-2012 07:27 PM
Long time pentaxian, first time poster originaljiggy Welcomes and Introductions 2 05-22-2010 11:28 PM
Long time lurker, first time poster Rob Irwin Welcomes and Introductions 7 02-19-2009 11:23 AM
Long time lurker, first time poster matthewk Welcomes and Introductions 5 02-12-2009 01:50 AM
Long time lurker; 1st time post cmstringer Welcomes and Introductions 1 01-26-2009 02:16 AM
All times are GMT -7. The time now is 01:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
