02-09-2011, 03:31 PM   #1
Manual aperture ring switch
Can turning the aperture ring on a lens damage the aperture motor on the pentax k7.
02-09-2011, 03:38 PM   #2
Don't think so. Why are you asking?
02-09-2011, 03:45 PM   #3
I have a problem with my pentax k7, only 3 weeks old and motor got stuck today. I can't think why and just checking a zoom I have to see if the aperture switch has been moved accidently. I never use manual aperture Ring so I can't see why it would be. Just can't figure out what has caused it. Looks like a call to jessops in the morning.
02-09-2011, 04:33 PM   #4
On digital, turning the aperture ring doesn't actually do anything except limit how far the stop-down lever will go, so no.
02-09-2011, 04:48 PM   #5
QuoteOriginally posted by richard978 Quote
I don't think the aperture ring is the culprit.
"Got stuck"? Can you describe the symptom in details.
Are the symptoms similar to the ones described in this thread.
02-09-2011, 06:01 PM   #6
v5planet's Avatar
I was wondering about this a bit. The only lenses I own are old pre-A series MF lenses, so I've never plopped a newer one on my camera.
So for instance you could stop an FA 77 down to f/2.8 with the aperture ring, but it actually stays wide open unless further directed by the camera's setting for aperture?
02-09-2011, 07:22 PM   #7
QuoteOriginally posted by v5planet Quote
Exactly. If you want to stop it down for some reason before taking the photo you would use the Optical Preview.
02-10-2011, 12:00 AM   #8
So using the aperture ring is something you can do? I would have thought it was the same as using the focus ring in auto
mode and damage the camera.
02-10-2011, 12:04 AM   #9
No, Using the aperture ring will not damage the camera. Also, Some lenses allow you to use the focus ring in auto focus as well. It's referred to as 'Quick Shift' and is a feature built into many of Pentax's modern DA type lenses (but not DAL).
aperture, camera, dslr, photography
Use of Aperture-Ring 43mm/1.9 -> no aperture data Deimo Pentax SLR Lens Discussion 7 06-24-2009 03:25 PM
zx-30 aperture switch nimionsergei Pentax Film SLR Discussion 2 11-20-2008 04:51 PM
Using aperture ring? audiobomber Pentax DSLR Discussion 6 10-07-2008 02:31 PM
Can the Aperture ring? kshapero Pentax SLR Lens Discussion 5 10-28-2007 06:25 AM
All times are GMT -7. The time now is 11:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
