10-18-2007, 02:49 AM   #16
Hi joelovotti
Here is the EXIF data for the last image, obtained using Firefox's invaluable add-on:
https://addons.mozilla.org/en-US/firefox/addon/3905
Exif IFD0
* Camera Make = PENTAX Corporation
* Camera Model = PENTAX K10D
* Picture Orientation = normal (1)
* X-Resolution = 720000/10000 = 72.00
* Y-Resolution = 720000/10000 = 72.00
* X/Y-Resolution Unit = inch (2)
* Software/Firmware Version = Adobe Photoshop CS2 Windows
* Last Modified Date/Time = 2007:10:17 19:34:00
* Y/Cb/Cr Positioning (Subsampling) = co-sited / datum point (2)
* Unknown tag: Tagnum = 0xc4a5 ===> data = 0x50,0x72,0x69,0x6e,0x74,0x49,0x4d,0x00,0x30,0x33,0x30,0x30,0x00,0x00,0x00,0x21,0x00,0x01,0x00,0x16,0x00,0x16,0x00,0x02,0x01,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0xd6,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x09,0x00,0x00,0x00,0x00,0x00,0x0a,0x00,0x00,0x00,0x00,0x00,0x0b,0x00,0x00,0x01,0x1e,0x00,0x0c,0x00,0x00,0x00,0x00,0x00,0x0d,0x00,0x00,0x00,0x00,0x00,0x0e,0x00,0x00,0x01,0x34,0x01,0x00,0x05,0x00,0x00,0x00,0x01,0x01,0xff,0x00,0x00,0x00,0x01,0x02,0x83,0x00,0x00,0x00,0x01,0x03,0x83,0x00,0x00,0x00,0x01,0x04,0x83,0x00,0x00,0x00,0x01,0x05,0x83,0x00,0x00,0x00,0x01,0x06,0x83,0x00,0x00,0x00,0x01,0x07,0x80,0x80,0x80,0x00,0x01,0x10,0x80,0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x02,0x07,0x00,0x00,0x00,0x00,0x02,0x08,0x00,0x00,0x00,0x00,0x02,0x09,0x00,0x00,0x00,0x00,0x02,0x0a,0x00,0x00,0x00,0x00,0x02,0x0b,0x00,0x00,0x01,0x44,0x02,0x0d,0x00,0x00,0x00,0x00,0x03,0x00,0x05,0x00,0x00,0x00,0x03,0x01,0xff,0x00,0x00,0x00,0x03,0x02,0x83,0x00,0x00,0x00,0x03,0x03,0x83,0x00,0x00,0x00,0x03,0x06,0x83,0x00,0x00,0x00,0x03,0x10,0x80,0x00,0x00,0x00,0x00,0x00,0x11,0x09,0x00,0x00,0x27,0x10,0x00,0x00,0x0f,0x0b,0x00,0x00,0x27,0x10,0x00,0x00,0x05,0x97,0x00,0x00,0x27,0x10,0x00,0x00,0x08,0xb0,0x00,0x00,0x27,0x10,0x00,0x00,0x1c,0x01,0x00,0x00,0x27,0x10,0x00,0x00,0x02,0x5e,0x00,0x00,0x27,0x10,0x00,0x00,0x00,0x8b,0x00,0x00,0x27,0x10,0x00,0x00,0x03,0xcb,0x00,0x00,0x27,0x10,0x00,0x00,0x1b,0xe5,0x00,0x00,0x27,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
Exif Sub IFD
* Exposure Time (1 / Shutter Speed) = 1/6 second = 0.16667 second
* Lens F-Number/F-Stop = 35/10 = F3.50
* Exposure Program = action program (high-speed program, fast shutter speed) (6)
* ISO Speed Ratings = 1100
* Exif Version = 0221
* Original Date/Time = 2007:10:13 11:24:43
* Digitization Date/Time = 2007:10:13 11:24:43
* Components Configuration = 0x01,0x02,0x03,0x00 / YCbCr
* Exposure Bias (EV) = 0/10 = 0.00
* Metering Mode = pattern / multi-segment (5)
* Flash = Flash did not fire, compulsory flash mode
* Focal Length = 2800/100 mm = 28.00 mm
* FlashPix Version = 0100
* Colour Space = sRGB (1)
* Image Width = 800 pixels
* Image Height = 573 pixels
* Image Sensing Method = one-chip color area sensor (2)
* Image Source = digital still camera (DSC)
* Scene Type = directly photographed image
* Custom Rendered = normal process (0)
* Exposure Mode = auto exposure (0)
* White Balance = auto (0)
* Focal Length in 35mm Film = 42
* Scene Capture Type = standard (0)
* Contrast = normal (0)
* Saturation = normal (0)
* Sharpness = hard (2)
* Subject Distance Range = distant view (3)
Exif IFD1
* Compression = JPEG compression (6)
* X-Resolution = 72/1 = 72.00
* Y-Resolution = 72/1 = 72.00
Best regards
Richard
camera, dslr, iso, k10d, noise, photography, photos, series, shot, tav, test
K-x vs K10D ISO comparison test photos rjm Pentax DSLR Discussion 21 12-01-2009 04:48 PM
Interesting DR Test and BG Noise Test of the K20D RiceHigh Pentax DSLR Discussion 14 06-25-2008 09:49 AM
k10d vs k20d ISO 1600 test PentaxPoke Pentax DSLR Discussion 9 05-11-2008 02:36 PM
ISO noise - pentax K10D is good? platinum Pentax DSLR Discussion 5 04-18-2008 03:24 PM
Some K20D Vs K10D ISO noise tests (100 to 6400) RiceHigh Pentax DSLR Discussion 15 02-25-2008 04:00 PM
All times are GMT -7. The time now is 08:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
