02-14-2011, 11:33 AM   #1
v5planet's Avatar
K-7 AF Adjustments
I've recently purchased a second autofocus lens, and have discovered the back focus problems I experienced with my first AF lens happen with the new one as well. This leads me to think something is off with my K-7, and it is severe enough that the AF microadjustments that can be done in the camera settings do not adequately compensate for it.
Is there any way to go beyond the +/- 10 adjustments? I'd prefer not to have to send my camera in to resolve this issue, as it is now out of warranty (even though the problem must have been there from day 1), and would prefer not to lose the use of my camera for several weeks.
Thanks all.
02-14-2011, 07:34 PM   #2
When you use your Takumars or other Manual focus lenses, and you get the in focus beep and confirmation, are the images in focus? Which AF lenses are you referring to?
02-14-2011, 08:06 PM   #3
v5planet's Avatar
I leave the focus beep off, but the flashing confirmation is usually close but not quite right. I habitually ignore it because it's not terribly accurate and use my own judgment by way of the split focus screen instead.
The two AF lenses I own now are the DA 35/2.8 and 15/4. I did some rigorous testing on a tripod with mirror lock up and remote cable shutter release using this back/front-focus test: http://focustestchart.com/focus10.pdf . Both lenses showed severe back focus that was almost fixed by a +10 AF adjustment, but not quite. This all leads me to believe the camera is the problem.
adjustments, af, camera, dslr, k-7, k-7 af, lens, photography
K7 adjustments Snydly Pentax DSLR Discussion 2 01-25-2011 06:11 PM
Struggling with autofocus adjustments JamieP Pentax DSLR Discussion 13 12-15-2010 01:31 PM
Auto focus adjustments basso4735 Pentax DSLR Discussion 11 08-19-2010 03:02 PM
How can different lenses have different focus adjustments? GregK8 Pentax DSLR Discussion 11 08-19-2010 10:01 AM
K20D AF adjustments ManuH Pentax DSLR Discussion 14 09-11-2008 02:47 PM
All times are GMT -7. The time now is 07:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
