Originally posted by gp1806 I have a DL that will not start with any batteries except Eneloops. Works fine on Eneloops, or Duracell rebranded Eneloops (same battery, different label). Have you tried Eneloops?
I think this may not just be one thing.
Mangusta is right - there is a capacitor - that acts like a flywheel determining the battery's status/level -
without a functioning capacitor then the Pentax dSLR probably would not even turn on.
However it also comes down the batteries too.
I believe the Pentax dSLR initialization draws some current from the batteries and measures the voltage.
Even if the capacitor is fine - if the batteries do not manage to maintain their voltage under load for this initial test -
they will still fail to power the camera - or turn on with low battery.
So the solution is two fold - use either Lithium AAs (like the ones supplied with the camera in the USA) or use eneloops (or confirmed re-badges) properly fully charged - if those fail to turn on the camera - then perhaps the capacitor needs replacing.
