02-19-2011, 12:52 PM   #1
eccs19's Avatar
K7 flash sync speed.
I've got a cheap set of flash triggers for my K7. Max sync speed I get is 1/160, then it jumps to 1/200. I thought 1/180 was max. I assume I'm missing something somewhere......
02-19-2011, 01:53 PM - 1 Like   #2
QuoteOriginally posted by eccs19 Quote
Change the EV steps in your custom menu.
02-19-2011, 02:04 PM   #3
eccs19's Avatar
QuoteOriginally posted by JeffJS Quote
Thanks, I'll have a look into that.
02-19-2011, 02:26 PM   #4
enoeske's Avatar
or switch it to X-sync mode
02-19-2011, 11:39 PM   #5
sterretje's Avatar
If you are 'complaining' that the camera will go to 1/200, the reason is more than likely that the camera is not aware of the flash; so it will allow you any shutter speed.
02-20-2011, 06:36 AM   #6
eccs19's Avatar
QuoteOriginally posted by sterretje Quote
Nope, not complaining at all. 1/160 works fine, I was just curious as to why I didn't see 1/180 when it's supposed to accept it. It's possible that using the cheap triggers is why it's like that, and that your assumption is correct, and it doesn't know there is a flash.
02-20-2011, 06:54 AM   #7
sterretje's Avatar
You can easily test that; select and ISO and aperture that basically will force a shutter speed faster than 1/180s. If the camera happily goes to 1/250s or 1/500s or even faster, it's not aware of the flash.
02-20-2011, 07:27 PM   #8
K-7 won't close the sync contacts at shutter speeds above 1/180 regardless of whether it thinks there is a flash there or not... Keep in mind that the cheapie triggers may not sync reliably at 1/180 anyway, so 1/160 is probably all you'll get, which should be OK anywho.
camera, dslr, flash, k7, max, photography, sync
Why is flash sync speed so important? harleynitelite Troubleshooting and Beginner Help 31 12-08-2010 05:52 PM
Is Flash Sync Speed limited by the body or flash? Reportage Troubleshooting and Beginner Help 16 09-16-2010 06:18 AM
Flash high speed sync. Deni Photographic Technique 22 08-26-2008 02:35 PM
Maximum flash sync speed jshurak Flashes, Lighting, and Studio 19 12-05-2007 12:13 PM
K100D flash sync speed Tyler Pentax DSLR Discussion 2 04-27-2007 12:08 PM
All times are GMT -7. The time now is 05:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
