10-16-2007, 04:02 PM   #1
K100D Super Debug menu
Does anyone know the key sequence for the debug menu of the K100D Super?
10-16-2007, 09:20 PM   #2
Hi Joel,
You must be wanting to live dangerously :-)
I wouldn't screw around with it while it's still under warranty.
Cgeers,
Rusty
10-17-2007, 04:06 AM   #3
QuoteOriginally posted by Rusty Quote
Hi Joel,
Cgeers,
Rusty
I don't plan on using it now, but I like to have all the information before I need it. I like information overload.
10-17-2007, 09:25 AM   #4
QuoteOriginally posted by joelw135 Quote
Use at your own risk - these are the instructions for
*istD(L) series, K100D and K110D DEBUG STEPS
(it might be possible this also applies to the K100D Super?)
1. Power OFF
While pressing [AE-L]+[INFO], turn the camera ON.
Firmware is desplayed on LCD.
Press [MENU]->[MENU]->[INFO] within 5 seconds.
You can see DEBUG mode screen.
By pressing [Right key>], change DEBUG MODE [DIS] to DEBUG MODE [EN].
Then, Press [OK].
2. Press [MENU], you can see setup menu.
3. Power OFF
By pressing [Right key], change DEBUG MODE [EN] to DEBUG MODE [DIS].
Then, Press [OK]. This shall return your camera into normal operation (non-debug mode);
Warning - Use entirely at your own risk
10-17-2007, 09:30 AM   #5
Moderator Emeritus
I think they 'fixed' that on the K10D and it can't be accessed anymore. The sequence was differnt but stopped working with Firmware 1.3
10-17-2007, 10:07 AM   #6
1. Power OFF
Then, Press [OK].
3. Power OFF
No doesn't work on Super, hope someone figures it out.
10-17-2007, 12:00 PM   #7
What sorts of things can you change in this debug menu?
Also can you damage the camera beyond repair, and how?
10-17-2007, 02:59 PM   #8
jgredline's Avatar
QuoteOriginally posted by Peter Zack Quote
Hi
I don't believe I ever updated the firmware on my K10D...Should I do it even if the camera is working perfectly?
What is the reason for de-bugging...?
Thanks folks..
10-17-2007, 03:51 PM   #9
QuoteOriginally posted by zook Quote
If your camera has front focus or back focus problems it can be adjusted, and a few other things.
10-18-2007, 04:23 AM   #10
raider's Avatar
My K100D has got front/back focus problem. Initially I use the debug menu to adjust the AF settings but find that the setting, while may be ok for 1 lens, will create havoc with other lenses.
Finally sent the body and all pentax lenses back to pentax for lens calibration. Pentax technician inform that some lenses (while attached to the body) are front focusing while some are back focusing.
They also informed that the debug menu (as per frequently discussed in the forum) is THE wrong way of adjusting the AF setting. They mentioned that the debug menu is required to be activated while they connect the body to the PC via USB port so that they can calibrate the body/lens from the computer software itself. They further say that the common way of setting the AF setting via the debug menu is wrong as Pentax would not, in their right mind, only allow AF setting for just 1 type of lens.
They mentioned that the body can be calibrated against "any" number of pentax lenses as the body will memorize the lens' signature (not serial number) and adjust its front/back focusing setting accordingly.
It seems that my camera is now much more better in AF accuracy now that it is calibrated. So I am happy.
camera, debug, dslr, k100d, k100d super debug, menu, photography
Debug menu for *ist DS v2.01+ jfsavage Pentax DSLR Discussion 6 12-13-2012 01:52 PM
K100d Super Debug Menu Instructions rmtschanz Pentax DSLR Discussion 5 04-28-2010 06:16 AM
Anyone know if 'debug' menu is available for Nikon cameras? jsherman999 Non-Pentax Cameras: Canon, Nikon, etc. 2 12-18-2009 07:07 PM
k100d Super Service Menu ChiZach Pentax DSLR Discussion 6 08-23-2009 03:53 PM
K10d-debug menu-IR possible? Bokeh Pentax DSLR Discussion 6 05-17-2008 05:54 PM
All times are GMT -7. The time now is 05:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
