02-23-2011, 04:51 PM   #1
K20 High Iso noise reduction - JPG only?
Hi Guys
i have searched but cant find an answer, does the high iso noise reduction in the C menu on the K20 only work for JPGS? i assume that is the case as raw is exactly as described... a raw image, but nowhere does the manual say that this is the case...
Thanks
02-23-2011, 05:58 PM   #2
SpecialK's Avatar
RAW is what the sensor sees. NR is after that in jpgs. You can take 3 RAW shots using different levels of NR and check the conversion.
camera, dslr, iso, iso noise reduction, k20, noise, photography, reduction
K-r High ISO Noise Reduction problem ions Pentax K-r 3 11-12-2010 01:11 AM
K-x high-ISO noise reduction: use it or do it in PP instead? richardm Troubleshooting and Beginner Help 5 10-28-2010 08:45 AM
Nikon high ISO noise reduction? MidwestMax Non-Pentax Cameras: Canon, Nikon, etc. 4 03-30-2010 02:09 PM
What do you guys use for high iso noise reduction? rustynail925 Digital Processing, Software, and Printing 38 12-04-2009 01:28 AM
K20D - High ISO Noise Reduction - How? How much? When? ksignorini Pentax DSLR Discussion 4 04-13-2008 01:14 PM
All times are GMT -7. The time now is 06:11 AM. | See also: NikonForums.com, part of our network of photo forums!
