Originally posted by Peter Zack Actually the focal length doesn't change. The FOV (field of view) does because the sensor is smaller some of the image projected back is not captured or cropped from what the lens can see on a full frame lens. On a DA series lens the image is cropped to match the sensor size. So the lens remains the same and to the best of my knowledge the DOF and HFD stay the same for the given focal range.
While what you state is true when you consider the raw image at the sensor, and providing that that image is enlarged to the same extent in printing, there is a practical aspect to consider here. We will enlarge the image from the digital sensor MORE.
Depth of field and hyper focal distance are things that were on 35 mm film standardized based upon a specific level of enlargement where the image was viewed not as perfectly sharp, but as acceptably sharp.
If we blow up an image, by 50% more (eg. making a 4 x 6 inch print from the "cropped image" of a DSLR), the definition of "acceptable" changes.
